Pouring gas without shaking?
night
I premix oil/gas and keep it for a week, 20:1.
If after a week of standstill can, I take the can and pour it into the shee without shaking, will that change the ratio.
In otherwords, will the oil go up and gas stay down.
So as I am pouring i will be putting all the oil first and then the gas.
So the can will now have only gas in it, right?
So next time I come to take the can and pour the supposingly oil/gas, it will be only gas?
I hope I was clear.
Thanks.
That a crazy question,but here u go.I dont mix the gas until I use it.If you let it sit the oil will settle to the bottom so shake it up before pouring.I would not recomwnnd 20:1 more like32:1 would be plenyt of oil.I usually mix 2 gallons at the time put 1 in pour the oil in andput the other gallon in the can.
Gas and oil will seperate over time.I rebuilt my yz125 top and lowend and suspension,it set for about a month i guess and did not think about it when i turned the fuel on but nothing but oil ran into carbs.I had to take them off and clean them.This was with maxima927.
Maybe your gas evaporated? I think that's the only way to seperate gas from oil. :confused:
Okay, now I have to test this for myself. I'll put some premix (Yamalube R) in a clear bottle with a lid on it and let ya'all know what happens. Might take a while though <_<
Edited by 8buck
This is true. But I've also heard the longer you let it sit mixed the lower the octane rating.
To make a higher octane rating the oil companies use fuels that have heavier molecules. When gas starts to evaporate the lighter molecules will go first. The more that evaporates the higher the octane goes. When your gas goes bad, a lot of the problem is that the octane is so high that it can't ignite. Many people think that higher octane means it's more explosive, it's not. You use higher octane to keep your bike from pinging (exploding)
I'm not sure, but I think oil also increase your octane
Edited by carter71
Well some of this is mostly right, others not at all. As mentioned octane is the rating of the fuel's resistance to combustion, ie. higher octane resists pre-ignition (PING, before it is fired by the spark plug) more than a lower octane fuel. Oil on the other hand does absolutely nothing to increase the octane. The oil is there to lubricate the cylinders and the bearings among other things (remember it has no crankcase lubrication other than the oil?). Oil does not burn, so I guess you could say it makes for a less combustable (less powerful) intake charge, but it does not do anything to resits PING.
