Slayer1018 Posted May 26, 2006 Report Posted May 26, 2006 Right here... I was using KLOTZ but this stuff is much better. Very tacky.... I don't see how anything could get through there. Quote
differentstrokes Posted May 26, 2006 Report Posted May 26, 2006 Never tried it, but I've always had good luck with maxima foam oil and their fab 1 spray too. Is it real thick when you pour it? Quote
DIRTMAN350 Posted May 27, 2006 Report Posted May 27, 2006 Foam. Hell k&n is the only way to go imo. Quote
Slayer1018 Posted May 27, 2006 Author Report Posted May 27, 2006 Foam. Hell k&n is the only way to go imo. 521287[/snapback] I keep hearing and reading that K and N filters let more dirt and dust through. To answer whether the oil is thick? It doesn't appear to be until you get it on your hands and it becomes stringy like glue... I pour it on a plate and roll my filter in it. Quote
rocketboy Posted May 27, 2006 Report Posted May 27, 2006 best foam filters thats like saying what is the best brand of rabbiit ears for my television . k&N is the only way to roll ,if the oil is thick and wont allow any dirt to possibly get through then yo ubetter belive it wont allow much of any air to get through either and air is what helps make power . runa outerware o nyour k&n and youll be just fine Quote
csrmel Posted May 27, 2006 Report Posted May 27, 2006 ive awalys had good luck with chainsaw bar oil. its tacky as hell and alot cheaper than those speciality foam oils. i think a gallon or bar oil is about $2 at walmart. Quote
differentstrokes Posted May 27, 2006 Report Posted May 27, 2006 I like k&n too, I run those on my banshee and foam on my trx450r. Quote
mnduner Posted June 7, 2006 Report Posted June 7, 2006 fab 1 spray on oil kicks ass. foam filters are better because they are thick and air moves through passages hitting oil on the way through where k&n is a layer with holes in it. my 02 always ran foam on my dirtbikes and have seen many turbos dusted from k&ns Quote
Hilarious Posted June 7, 2006 Report Posted June 7, 2006 I have yet to see a foam air filter last as long as a K&N. I've had some uni foam filters that have rotted and fallen apart when the K&N was still in one piece. I used some No Toil oil and cleaner when I had the foamies and it worked well. Just my .02$ Quote
brock_fuzzy_69 Posted June 8, 2006 Report Posted June 8, 2006 i can most certainly agree with a kand N filter letting ina ton of dust my shee had a pro design plate with a big K N with an outerwear an the inside of that filter was pure dust everywhere Quote
yyz Posted June 8, 2006 Report Posted June 8, 2006 best foam filters thats like saying what is the best brand of rabbiit ears for my television . k&N is the only way to roll ,if the oil is thick and wont allow any dirt to possibly get through then yo ubetter belive it wont allow much of any air to get through either and air is what helps make power . runa outerware o nyour k&n and youll be just fine i agree... but if you are running foam (i used to), then the yamaha or the maxima are both really good... i think they are they same thing... both blue, both tacky, both smell the same... no probs with the k&n's however... woudn't run anything else... at least two main jet sizes bigger with the k&n's w/outerwears compared to the same size oiled foam filter... and, 1/4 the maintainance... yyz Quote
dawarriorman Posted June 11, 2006 Report Posted June 11, 2006 Yeah, you K&N people can have them. Maybe on a car, but not anything that goes through as much dust as a quad. I've changed too many peoples K&N filters and seen all the dust on the inside of their intake for me to ever trust one of those. Foam won't let a thing through. And I've tried super tacky oils before (Bel Ray, even brake cleaner won't get that stuff off your hands), and finally switched to PJ1 in the spray can. Works just as well, really easy to put on, and it comes off really easy with their spray on cleaner. Quote
