Going from FMF Gold Series Fattys to T6s
aight, another update:
it was the basket. i took the hinson basket out of the other banshee and used it and prob solved. now ive got another prob. somewhere, somehow, there is anti-freeze leaking into my right cyl. i think its just a bad o-ring, besides that, it runns like a striped ass ape on speed :bolt: if it aint one thing, ITS A FUCKING 'NOTHER :shootself:
Ha...
You've got it easy...
I just built my 4 mil cub...still not running right.
All kind of small issues. Latest one is either CDI, Coil or Stator....
If you going to take the head off, for 20 bucks I'd replace all the orings.
I put just a thin coat on all the orings of hi temp RTV. Also...drain all the coolant from your block. The front two studs over the exhaust ports go into the water jacket...permatex those threads, too.
Good luck....:)
i only pay $16 for the last oring kit. but anyway, i got it running with no leaks finally. had a cutting out prob at 1st on friday, find out that the plugs i was using when it blew were shot from the piston frying it. put the old plugs in (still in good shape, just not irdium (sp) ) and prob solved. ran good all night saturday (took it to another party, no one else rode it but me this time) sunday had probs though. a wire on my key switch busted, so i just crossed the wire before the switch and were up and running again. also had a little trouble with it cutting out and acting liek it wasnt getting enough gas in the trail. took it out on the pavement and opened it and havent had a lick of trouble since then, rode for like 3 more hrs after that, so idk. its running good and thats all im worried about. thanks for the help guys :cheers::cheers:
