Best Clutch
bansha60
what do your clutch parts look like? is your basket grooved?is the pressure plate worn? if so, they can cause a new clutch to go bad quick. i see that your bike is a 98. are those clutch parts in it also 98 parts? i think id look into buying a magnum basket and new inner hub and pressure plate. i ran all new stuff with the FAST clutch in my 421 cub for over a year with no issues. i would also recommend a lockup. id say you are def in the power range for needing one. give FAST a call, he can set you up with what you need to get up and running the right way. 1-785-364-5325
