DemonShee Posted May 17, 2006 Report Share Posted May 17, 2006 My motor is a 4mm stroker long rod, dune porting by redline racing, cool head with three different sizes of domes, FMF fatty gold pipes w/powercores, 35mm airstryker carbs, vito's intakes, and boysen reeds. My question is what timing advance should I run? Keep in mind I ride high altitudes from 4000ft up 11,000ft. I see commonly on here +4, I talked to packerd racing from nearby Utah and he said run +7. Would like to see what everyone thinks. Thanks Quote Link to comment Share on other sites More sharing options...
wesw Posted May 18, 2006 Report Share Posted May 18, 2006 (edited) depends on your fuel if high octane try +7 but it will probably like +4-5 +7 is common for dragging but with fmf, i dont see you doing that all the time. Edited May 18, 2006 by wesw Quote Link to comment Share on other sites More sharing options...
rocketboy Posted May 18, 2006 Report Share Posted May 18, 2006 depends on your fuel if high octane try +7 but it will probably like +4-5 +7 is common for dragging but with fmf, i dont see you doing that all the time. 517398[/snapback] yep thats true ^^^^^^^ Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted May 18, 2006 Report Share Posted May 18, 2006 Mr. Packard knows two strokes better than most-no one can doubt that-but +7 timming does sound like a lot-start at +4 and go from there. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted May 18, 2006 Report Share Posted May 18, 2006 Demon, your welcome to pm me or call anytime and i will try to help you out. You should prolly call Redline since he did the motor but since you said "dune port" i would say prolly 4-5 degrees timing should work with your port timing! More aggressive porting (drag) and better race fuels can get away with more timing usually. Quote Link to comment Share on other sites More sharing options...
89Steeda Posted May 18, 2006 Report Share Posted May 18, 2006 Call cameron. Quote Link to comment Share on other sites More sharing options...
