ban1 Posted May 16, 2006 Report Share Posted May 16, 2006 do the o rings have to be replaced when changing domes Quote Link to comment Share on other sites More sharing options...
Yaxy Posted May 16, 2006 Report Share Posted May 16, 2006 (edited) Typiall O'rings do not need to be replaced unless they are brole ,cracked or warped. Personally I replace them everytime I rebuildd which is every two years. If you change domes quite frequently and the rings are ok then I would not wory about it. If you plan on keeping the domes in for a while buiy new rings, They are only about $20 Chris Edited May 16, 2006 by Yaxy Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted May 16, 2006 Report Share Posted May 16, 2006 Not unless, they are torn or defective. You can reuse them several times, but after some time, they will get hard and crack. If they get hard, or crack, or tear, then you need to replace them. Quote Link to comment Share on other sites More sharing options...
thegroup Posted May 16, 2006 Report Share Posted May 16, 2006 Typiall O'rings do not need to be replaced unless they are brole ,cracked or warped. Personally I replace them everytime I rebuildd which is every two years. If you change domes quite frequently and the rings are ok then I would not wory about it. If you plan on keeping the domes in for a while buiy new rings, They are only about $20 Chris 516638[/snapback] ive found them cheaper at magicracing.com. i think like $16 or $17 shipped Quote Link to comment Share on other sites More sharing options...
ban1 Posted May 16, 2006 Author Report Share Posted May 16, 2006 i have had the bike for about a year and never had it appart but i have 18cc domes in it and every one says they are to small and go with bigger ones fore pump gas they say that is probably what is causing by bog when i hit the gas Quote Link to comment Share on other sites More sharing options...
thegroup Posted May 16, 2006 Report Share Posted May 16, 2006 i have had the bike for about a year and never had it appart but i have18cc domes in it and every one says they are to small and go with bigger ones fore pump gas they say that is probably what is causing by bog when i hit the gas 516642[/snapback] depending on where u live, 20cc u can still run 91 oct. i run 100 oct AV Gas in mine with 18 domes and havent had any probs, exp. sat night. ran it low on gas and i think i leaned it out and burn a hole in the piston Quote Link to comment Share on other sites More sharing options...
ban1 Posted May 16, 2006 Author Report Share Posted May 16, 2006 my brother has a set of 19cc domes he said he would give me i thought i could try them and see if it makes any dif at all i know it is just one size bigger but it mite help a little and im at 2900 ft Quote Link to comment Share on other sites More sharing options...
