xieatcatbrainsx Posted May 16, 2006 Report Share Posted May 16, 2006 the left side of my shee' doesnt seem to put out much. i took off the exhaust and got some mixxed gas out of it. i think it isnt supposed to but i dont have any power at low engine speed like if you let the clutch out slow and then gas it it takes a while to build RPM and hit its power curve. white smoke comes out of the right exhaust pipe and you can feel the pressure with gas. at an idle both sides are even. when i ride the left side seems to not smoke. is this normal? am i losing compression and have to rebuild which would suck cause i dont know how. help me please. Quote Link to comment Share on other sites More sharing options...
Kunda Posted May 16, 2006 Report Share Posted May 16, 2006 Id check the spark on da left side, either plugs r wires. Might just be blowin gas right thru it. Have ya dun a compression test on da left side yet? at could tell ya if its bad r not but it sounds ta me like that sides just not sparkin r is doin so erradically. Quote Link to comment Share on other sites More sharing options...
apbt549 Posted May 16, 2006 Report Share Posted May 16, 2006 like he said check the compression it sounds like the one side is not firing...how hot is the pipe can you touch one and not the other if so then it is not firing for some reason...... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 16, 2006 Report Share Posted May 16, 2006 Or it's a fuel problem. Plugged line, plugged jet, etc. Try new spark plugs gapped at .028, then...swap coil wires. See if one or the other helps... Quote Link to comment Share on other sites More sharing options...
xieatcatbrainsx Posted May 16, 2006 Author Report Share Posted May 16, 2006 hmm i think its my coil or one of the wires bcause when i X the wires the cylinder not firing changes... looks like the wires go straight into the coil tho do i have to replace the whole thing? ($50) its no big deal if i do. thanx to all u + keep up the good werk Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 17, 2006 Report Share Posted May 17, 2006 Not sure if you can replace just the wire...but I think I'd be buying a new Coil just to be safe... Quote Link to comment Share on other sites More sharing options...
wesw Posted May 17, 2006 Report Share Posted May 17, 2006 check the sync of your carbs. Quote Link to comment Share on other sites More sharing options...
