cdwood37 Posted May 15, 2006 Report Share Posted May 15, 2006 i have 35mm airstrykers and was wondering what my float level should be how do i measure it and what should it be. I am running out of fuel on the right side when i am am WOT i don't have a pingel valve so that might be it. I would like to know though. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 Unless you're running alcohol...you probably don't need a pingel. Pingels sure are nice, but overkill for your (our) motor.... As posted in your other thread, I think it's 16mm for the Kehin. Call Jeff...he'll know for sure... Is your fuel line kinked or bent? try to find a Y adapter instead of that T...I'd invest in clear hoses, too...make sure fuel delivery is your problem. Quote Link to comment Share on other sites More sharing options...
cdwood37 Posted May 15, 2006 Author Report Share Posted May 15, 2006 also, is 1/4" hose the right size for fuel hose? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 I use 5/16.... Quote Link to comment Share on other sites More sharing options...
ak47banshee Posted May 15, 2006 Report Share Posted May 15, 2006 you know what you do.... (have your bike off.) take your pods off, look upside down into your carbs and pull your throttle. make sure the slides reach the top at the same time. if not then adjust the pull screw. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 That is a good point, often overlooked. Aside to making sure your carbs are sync'd...check the fuel line for restriction. That baby should rip.... Quote Link to comment Share on other sites More sharing options...
