Compression sound right
I finally got the Banshee put back together and checked the compression. It only had 120 pounds of compression on both cylinders. It now has 69.5mm pistons, and a Wiseco 4mm stroker. Do these numbers sound right? other than the pistons, and crank everything is stock in the engine.
I have the stock head, Elevation is around 1000 feet above sea level. No domes and I dont know if it was ported, the edges of the ports have been smoothed and appear to have been rounded.
Forgot to mention, I have Trinity stage 4 intakes, 35mm carbs and k & N Filters with outerwares.
The stroker came with the spacer plate and longer studs.
