bodge Posted May 14, 2006 Report Share Posted May 14, 2006 I have one of these sat doing nothing, should i fit it or sell it or bin it? My shee has got a the timing set at +4. pipes v3 reeds carbs jetted http://cgi.ebay.com/ebaymotors/ws/eBayISAP...Y_BIN_Stores_IT Quote Link to comment Share on other sites More sharing options...
racer Posted May 15, 2006 Report Share Posted May 15, 2006 ive read bad things on here about that product. but fit it up and tell us what you think. maybe you can sway the vote. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 My biggest problem is it claims to give you 1000 more RPM. Well, in two stroke land, ignition doesn't limit RPM, porting, compression, timing, pipes and carbs do that.... So, it's a lie up font, which would make me weary...however, never used one, so I can't say if it's a good product or not! Quote Link to comment Share on other sites More sharing options...
bodge Posted May 15, 2006 Author Report Share Posted May 15, 2006 the thing that worry's me is will it change my ign timing to much with it being set at +4 and do some damage? come on guys must be some tech's out there. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 If you already have the timing plate, what do you hope to gain from this? Get a stock CDI..they work fine. Or, get a Dyna... Unless you're running wild compression and/or alcohol...stock CDI is just fine... Quote Link to comment Share on other sites More sharing options...
bodge Posted May 15, 2006 Author Report Share Posted May 15, 2006 If you already have the timing plate, what do you hope to gain from this?Get a stock CDI..they work fine. Or, get a Dyna... Unless you're running wild compression and/or alcohol...stock CDI is just fine... 516373[/snapback] Thats what im asking, will i gain anything? If not then i will sell it. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 15, 2006 Report Share Posted May 15, 2006 Sell it... I'd rank it with Boost Bottle, Amp Link, and the purple powerband... Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 15, 2006 Report Share Posted May 15, 2006 Sell it... I'd rank it with Boost Bottle, Amp Link, and the purple powerband... 516377[/snapback] Agreed! There is no Rev limiter in the first place on a stock CDI as mentioned above. You might have to pay someone to take it. Quote Link to comment Share on other sites More sharing options...
fast500#12 Posted May 17, 2006 Report Share Posted May 17, 2006 it looks exactly like and has the same part number of the pro com junk. get rid of it. Quote Link to comment Share on other sites More sharing options...
