banshee#1 Posted May 11, 2006 Report Share Posted May 11, 2006 hey im sorta new to workin on my banshee nd ino the engine nd stuff but ijust got ported nd neeeded a rebuild how do u take the pistons off the crank ?? thanks. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 11, 2006 Report Share Posted May 11, 2006 Better get a Clymers manual. Quote Link to comment Share on other sites More sharing options...
banshdog Posted May 11, 2006 Report Share Posted May 11, 2006 you mean pistons off the rods? Quote Link to comment Share on other sites More sharing options...
13th Grave Posted May 11, 2006 Report Share Posted May 11, 2006 Pull off your cylinders and take the circlips out with needle nose plyers and knock the sleeve through and they should come off but your best bet would be to get a clymers manual first. Quote Link to comment Share on other sites More sharing options...
IamKazam Posted May 11, 2006 Report Share Posted May 11, 2006 Yess, def. get a clymers. They explain things like this in a "step by step" procedure Quote Link to comment Share on other sites More sharing options...
MILO Posted May 12, 2006 Report Share Posted May 12, 2006 i agree, definitely get a clymer's manual. it'll be the best $30 you ever spend on the shee. there's a small circlip on each side of the wrist pin that sits in a slot in the piston. there is a small open area in the piston where you can fit small needle nose in there to pull out the clip. make sure you have some rags covering the crank opening in case you drop the clip or you'll be into more than the top end. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted May 12, 2006 Report Share Posted May 12, 2006 When you get the little c-clips off, its best not to "beat" the wrist pins out, putting stress on the crank. Yeh, get a clymers, they show you how to make a little tool to get the wrist pins out too. Quote Link to comment Share on other sites More sharing options...
