assembly questions
i dissasembled my shee last winter and i am getting it back together now cant remember where everything goes.
1 what are teh 2 plugs on the wiring harness around/above the carb for?
2 does the harness pretty much just follow the upper frame tube from front to back?
3 removed park brake cable and lever and wiring. what do you guys get for a clutch lever and perch, or do you just leave the giant perch for the pb?
thanks pete
thanks pete
514166[/snapback]
#1 sorry I can't help ya there. Post some pics and it might be easier.
#2 Get a clymers manual and it will show how the harness and cable routing goes
#3 I removed the stock perch and replaced it with a quick adjust msr perch. Works pretty good for me. I here asv makes a pretty good perch.
thanks for the help i got single carb so i guess dont worry about the connectors. :confused:
im gona get the clymers from previous owner this wekend thatll prolly tell me ^ also
are dirtbike levers the same length as stock? my clutch pull is really hard ive lubed it but no help??
Edited by mnduner
i used a grinder and trimmed up the stock perch. figured i'd give it a shot before getting a new one. here's a pic after repainting it, and some use of course.
Edited by MILO
