avc8130 Posted May 7, 2006 Report Share Posted May 7, 2006 So my Outerwears over my Pro Design foam filter is killing me. I had it on last weekend and suddenly my quad lost all power and wouldn't run right. I took it off and it ran great again. Obviously it was clogged up. So I went and cleaned it at home the best I could. Went to ride today and again it wouldn't run with it. I took it off and noticed it was still a bit clogged in some spots. How do you clean these things? ac Quote Link to comment Share on other sites More sharing options...
astars25 Posted May 7, 2006 Report Share Posted May 7, 2006 So my Outerwears over my Pro Design foam filter is killing me. I had it on last weekend and suddenly my quad lost all power and wouldn't run right. I took it off and it ran great again. Obviously it was clogged up. So I went and cleaned it at home the best I could. Went to ride today and again it wouldn't run with it. I took it off and noticed it was still a bit clogged in some spots. How do you clean these things?ac 512784[/snapback] i just clean mine after every ride with soap and water then i just spray it with an air hose to dry it out then let it sit over night so its really dry then i put them back on.... never had any problems with mine... good luck with it tho Quote Link to comment Share on other sites More sharing options...
daryn c Posted May 7, 2006 Report Share Posted May 7, 2006 clean it with gas or something thats a solvent Quote Link to comment Share on other sites More sharing options...
avc8130 Posted May 7, 2006 Author Report Share Posted May 7, 2006 Well, I ran it through the washer machine with my riding gear. I used some Spray N Wash on it. It seems much cleaner now. I can see through the whole thing now. I will try it again next weekend! ac Quote Link to comment Share on other sites More sharing options...
avc8130 Posted May 30, 2006 Author Report Share Posted May 30, 2006 Well, I took it out for a ride and again it would just bog and never come on the power. When I slip the outerwears off it runs like a raped ape! It is very weird. I cannot believe how restrictive this outerwears could be! ac Quote Link to comment Share on other sites More sharing options...
RIPPEN Posted May 30, 2006 Report Share Posted May 30, 2006 After several good rides I just clean both filter and outterwears.. Iam not sure if your supposed to but I use the same spray on the outterwears as you use on the filters to clean out the dirt and oil... Seems to work good, havn't had any problems yet. RIPPEN Quote Link to comment Share on other sites More sharing options...
ellison445 Posted May 30, 2006 Report Share Posted May 30, 2006 Same here After several good rides I just clean both filter and outterwears.. Iam not sure if your supposed to but I use the same spray on the outterwears as you use on the filters to clean out the dirt and oil... Seems to work good, havn't had any problems yet. RIPPEN 522324[/snapback] Quote Link to comment Share on other sites More sharing options...
racer Posted May 30, 2006 Report Share Posted May 30, 2006 clean it with gas or something thats a solvent 512819[/snapback] careful. catch a solvent thats too caustic and youll need a new outerwear. Quote Link to comment Share on other sites More sharing options...
dinicolada Posted May 30, 2006 Report Share Posted May 30, 2006 Have you tryed cleaning the filter itself it maybe derty and the outerwaer is just making it so no air passes Quote Link to comment Share on other sites More sharing options...
avc8130 Posted May 30, 2006 Author Report Share Posted May 30, 2006 The filter looks super clean. I am going to run it without the outerwear until the filter is dirty and then clean everything. The filter I am using is a Uni 2 layer. ac Quote Link to comment Share on other sites More sharing options...
mnduner Posted May 31, 2006 Report Share Posted May 31, 2006 ive always used nonclorinated brake cleaner. aerosol cans like 1.50 at any parts store and its fun to burn too. Quote Link to comment Share on other sites More sharing options...
Dark Ranger Posted May 31, 2006 Report Share Posted May 31, 2006 Does the outerwear compress the filter a lot? If it does it could be restricting the air flow. Quote Link to comment Share on other sites More sharing options...
DIRTMAN350 Posted May 31, 2006 Report Share Posted May 31, 2006 I run a pro-desing plate with a K&N filter with outerwear and have not had any problems yet. I too clean mine after every ride. Use the same cleaner for air filter and outerwear. Quote Link to comment Share on other sites More sharing options...
