Satsol67 Posted May 4, 2006 Report Share Posted May 4, 2006 Hi eveyone. I am having a problem with my 2000 Banshee 350 and was wondering if someone could point me in the right direction. I have to dump fuel in the head to get it started when it is cold. After it fires the first time it will fire right up. I am thinking it might be a problem with the rings. Any suggestions would be very helpful. Thank you Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 4, 2006 Report Share Posted May 4, 2006 I would buy a good compression tester (Name brand, not cheapie junk one) and test your compression. Anything more than 10% difference between the two cylinders and/or less than 100PSI means it's rebuild time. A good machine/engine shop should be able to Mic (measure) the cylinders and pistons to see if they are past wear limits...or if they can be re-used and re-rung. Quote Link to comment Share on other sites More sharing options...
MILO Posted May 5, 2006 Report Share Posted May 5, 2006 carb bowls switched or crossover tube missing?? Quote Link to comment Share on other sites More sharing options...
DIRTMAN350 Posted May 5, 2006 Report Share Posted May 5, 2006 Just wondering if you are using your choke???? Also i'm sure you have heard this before but is your gas turned on? Might want to think about a clymers manual for your shee. I just got one and it is way better than the oem service manual. Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted May 5, 2006 Author Report Share Posted May 5, 2006 I will get a good compression tester. I was just wondering if that would cause the cold start problems. I have only had this 2 weeks now and I dont know any of the history. The guy that had this before me had no clue and should have never owned this in the first place. I do plan and rebuilding the motor I just would like to get through the summer. As for the cross over tube yes it is there. All in all it runs good. When I get done with it, it will be one sweet machine! The owner before the one i got this from took care of it. Did mods to it like lone star front end, Cool head, Toomey pipes, extended swing arm. Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted May 5, 2006 Author Report Share Posted May 5, 2006 Yes i tried the choke and no luck. As for the gas being on once it is running i ride the hell out of it. So if the gas was off I dont think I would be able to do that. I agree about the manual. I have the OEM one and it blows. Time for a good one. Quote Link to comment Share on other sites More sharing options...
DIRTMAN350 Posted May 5, 2006 Report Share Posted May 5, 2006 I just thought i would bring it up because some people think too hard about it and froget all about the gas being turned on. I didn't to disrespect ya. Sorry man. Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted May 5, 2006 Author Report Share Posted May 5, 2006 its all good man. Nice ride you have there. I see you have a temp gauge on it. That was something I was wondering if could be done. I found were to get it from. How do you like yours? I am a newbie when it comes to the shee's. I have some newbie questions like. What should I be mixing the gas at? I have been mixing it 31:1. I know the motor needs to be rebuild. Barings anyhow. It has a knock to it I dont like. I think this chain is a little to loose. But I dont see how to tighen it up. Goes back to needing a good manual. The OEM isnt much help. Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted May 5, 2006 Report Share Posted May 5, 2006 the chain adjusters are on the back axle in the rear of the bike you have to loosen the axle swing bolts abd loosen the lock nuts then screw them in they have to be turned the same amount ( count your threads ) or the axle will be turned one way too much and It will dogleg while riding. Quote Link to comment Share on other sites More sharing options...
thegroup Posted May 5, 2006 Report Share Posted May 5, 2006 its all good man. Nice ride you have there. I see you have a temp gauge on it. That was something I was wondering if could be done. I found were to get it from. How do you like yours? I am a newbie when it comes to the shee's. I have some newbie questions like. What should I be mixing the gas at? I have been mixing it 31:1. I know the motor needs to be rebuild. Barings anyhow. It has a knock to it I dont like. I think this chain is a little to loose. But I dont see how to tighen it up. Goes back to needing a good manual. The OEM isnt much help. 512203[/snapback] Def. get a Cylmer (sp) manual. itll tell u everything u need to know. im running my 'shee at 32:1 on 100 oct AV Gas with Castor 927. by the way, temp gauges r easy to put in. V V V Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 5, 2006 Report Share Posted May 5, 2006 Yes, low compression will cause problems w/ cold starts. I would check the compression. Check your bowls to see if they were ever reversed. I see it was mentioned above, but not explained to you. If you put the bowls on the wrong carb(they will fit, and even look the same) the choke will not work properly. In the bottom of the bowl they are numbered, 1-1, and 1-2. 1-1 goes on the left side or side w/choke pull. Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted May 6, 2006 Author Report Share Posted May 6, 2006 I checked the carb bowels and they are put on right. Time for the manual. Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted May 7, 2006 Report Share Posted May 7, 2006 (edited) a plugged pilot jet will cause a cold start problem. bad reeds will also cause a cold start problem Edited May 7, 2006 by FIRST BANSHEE Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted May 7, 2006 Author Report Share Posted May 7, 2006 HOw do you test the reeds to see if they are bad? When I got it i noticed that one of the bolts were loose so i pulled off both reeds and looked at them. I did see anything wrong with them. Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted May 7, 2006 Report Share Posted May 7, 2006 you can just look them over and see if any are stuck open or cracked Quote Link to comment Share on other sites More sharing options...
