LeadBoots Posted April 21, 2006 Report Share Posted April 21, 2006 is it easy to drill and tap the hole for the new idle screw? i bought the kit off ebay will it have direction or should i take it to a shop. Quote Link to comment Share on other sites More sharing options...
Gargamel Posted April 21, 2006 Report Share Posted April 21, 2006 you can do it it's not hard at all, if they don't come with good enough instructions you can ask here and we'll help with detailed step by step help Quote Link to comment Share on other sites More sharing options...
FasterThanU90 Posted April 21, 2006 Report Share Posted April 21, 2006 just keep it really lubed up and it shoud be easy Quote Link to comment Share on other sites More sharing options...
Wallrat Posted April 21, 2006 Report Share Posted April 21, 2006 just keep it really lubed up and it shoud be easy 505538[/snapback] Remember that advice...it will serve you well one day. Quote Link to comment Share on other sites More sharing options...
watkins Posted April 21, 2006 Report Share Posted April 21, 2006 (edited) Yes drilling/tapping the carbs is easy... just take it slow. Sweet sig wallrat Edited April 21, 2006 by watkins Quote Link to comment Share on other sites More sharing options...
jaysea1 Posted April 22, 2006 Report Share Posted April 22, 2006 Use a drill press. level, and secure the carb on the table of the drill press, lube with wd40 or all purpose oil while drilling and most importantly tapping(3 turns in then back out the tap clean threads, relube etc.) Shave the bosses level, (with a mill file)then take a little more off(just a little) so the idle screw makes good contact with the slide and lifts it up. Follow the directions in the kit carefully, and make all your adjustments after installation(sync the carbs, set the idle) Also after drilling and tapping wash the carbs out and blow em out with compressed air. If you need directions, go to Toomey's web site under tech installations, idle kit. Quote Link to comment Share on other sites More sharing options...
