twist throttle tors removal
They're all the same....
Make sure you get the carb caps, Drill, tap and two brass idle screws with locking nuts.
Also...make sure you get the correct throttle cable...too.
Motion pro sells the twist throttle kit, plenty sell the idle kit....
I have a twist throttle that got used two or three times I'd let go for cheap, if you're interested.
I also have a spare set of carb caps, minus the dust booties.
All you'd need is the idle screws...I have three sets of the drill and tap (I've done mine and two other buddies...)....
Let me know if you're interested...
You sure you wanna go twist...shees are a handful in the trail...and I come from a dirtbike background to boot.
