race-a-holic Posted May 3, 2006 Report Share Posted May 3, 2006 (edited) I don't think you'll run away from the piped raptor.I had one as well as piped banshees.I had a similar banshee except with FMF fatties.My buddy had a raptor with a full CT pipe,filter,etc...I would jump ahead of him in 2nd and 3rd gear.He couldn't make up this difference but I couldn't pull away from him after 3rd either.A piped raptor runs pretty good. Port that banshee and you'll smoke that raptor. Edited May 3, 2006 by race-a-holic Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted May 3, 2006 Report Share Posted May 3, 2006 (edited) If you have Low end pipes, stock gearing and heavy ass tires. I think it is likely that he will stomp you. The way I see it... A boost bottle is just for decoration and Toomy is foam filter that flows less than a K&N, +4 timing will help some but not much and Boysen Reeds are probably not giving you anything other than slight improvement in throttle response since your using stock carbs and no porting. So your only real performace mods are Low End Pipes. So Yea I would think a built raptor could beat you pretty easy. Especialy if you have really heavy tires, since extra tire mass affects your acceleration about the same as 10x regular mass, so if your tires are 10lbs heavier than stock it would affect your acceleration about the same as adding 200lbss to your bike. If you were on sand an d lightweight paddles you would have a better chance. If you had some porting and some different pipes you would easily walk him. Edited May 3, 2006 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
2bzy2p Posted May 3, 2006 Report Share Posted May 3, 2006 (edited) I don't think you'll run away from the piped raptor.I had one as well as piped banshees.I had a similar banshee except with FMF fatties.My buddy had a raptor with a full CT pipe,filter,etc...I would jump ahead of him in 2nd and 3rd gear.He couldn't make up this difference but I couldn't pull away from him after 3rd either.A piped raptor runs pretty good. Port that banshee and you'll smoke that raptor. 511468[/snapback] a piped raptor is still slow!!!!! Edited May 3, 2006 by 2bzy2p Quote Link to comment Share on other sites More sharing options...
race-a-holic Posted May 7, 2006 Report Share Posted May 7, 2006 a piped raptor is still slow!!!!! 511549[/snapback] Just depends on what you compare it to. Quote Link to comment Share on other sites More sharing options...
Slayer1018 Posted May 15, 2006 Report Share Posted May 15, 2006 JustinToxicated Wrote... "Toomy is foam filter that flows less than a K&N" You are so wrong Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted May 15, 2006 Report Share Posted May 15, 2006 Your pipes do kill your top end some.I ported my brothers shee,and he had those pipes and even still could pull good on a 1/2 mile flat trak. ditch those heavy tires,get it ported,Iwould say 15 front sprocket and 20 rear tires.Pro circuit pipes would be better,but not a must have to beat a raptor.Raptors are underated though,I bought one and the torque ,and less wheel spin is great,how,ever would not touch my old shee on a longer straight. Quote Link to comment Share on other sites More sharing options...
scottsh80 Posted June 15, 2006 Report Share Posted June 15, 2006 Weird! I smoked a 660R with pipes on my stock (02) banshee... Quote Link to comment Share on other sites More sharing options...
txraptor Posted June 17, 2006 Report Share Posted June 17, 2006 Never underestimate the power of a good running Raptor Quote Link to comment Share on other sites More sharing options...
race-a-holic Posted June 18, 2006 Report Share Posted June 18, 2006 Hey what's guys this is my first post. I raced my brother on his raptor 660R this weekend all he has done is full pipe, K&N air cleaner and gearing change. I raced him a bunch of times on dirt and pavement he beats me every time. Even if we start from a roll we are dead even nobody pulling away. My mods are FMF gnarly pipes powercore silecers,boost bottle,boysen reeds,+4 timing,toomey air cleaner kit. Does this sound right or is my banshee low on power for its mods. thanks for any help. What gearing,jetting,etc... do you have? I'm not a big fan of FMF.They are better than stock but what isn't.LOL! For a stock port or even ported banshees,I've had good luck with T-5's. For a ported banshee,CPI pipes are really good and shearers are awesome. Quote Link to comment Share on other sites More sharing options...
400rednEX Posted June 23, 2006 Report Share Posted June 23, 2006 throw the realters away and get some 20" razrz Quote Link to comment Share on other sites More sharing options...
Yamashee1 Posted September 5, 2006 Report Share Posted September 5, 2006 Im not sure if this is any thing really to brag about. But it is the only quad I have Raced since my last mods. but I raced a buddie of mine with a Polaris 400 sport. pretty much stock cept he has carbon fiber reeds and a k&N Filter and 2 teeth smaller on his Rear Sprocket. Of corse I beat him. even when i gave him 6 lengths head start.and I too never hit 6th gear. but im not sure how fast a 400 sport really is.we have Raced before when i was all stock and i would beat him by a few lengths. so I have seen a Big Diff, since my last mods wich were The Toomey 2 into 1 Airfilter (air box gone).and a set of RocketPipes, and 280 jets. Im going to change my front sprocket to a 15th.it was kinda scary when I took off in 2nd with throttle Pinned the front end came up so fast I had to let off the gas for a split second to drop the front end. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted September 6, 2006 Report Share Posted September 6, 2006 Im not sure if this is any thing really to brag about. But it is the only quad I have Raced since my last mods. but I raced a buddie of mine with a Polaris 400 sport. pretty much stock cept he has carbon fiber reeds and a k&N Filter and 2 teeth smaller on his Rear Sprocket. Of corse I beat him. even when i gave him 6 lengths head start.and I too never hit 6th gear. but im not sure how fast a 400 sport really is.we have Raced before when i was all stock and i would beat him by a few lengths. so I have seen a Big Diff, since my last mods wich were The Toomey 2 into 1 Airfilter (air box gone).and a set of RocketPipes, and 280 jets. Im going to change my front sprocket to a 15th.it was kinda scary when I took off in 2nd with throttle Pinned the front end came up so fast I had to let off the gas for a split second to drop the front end. yeah, the Polarises are slow, that auto tranny really kills 'em too. Your running a 280 main, with an open filter and rocket pipes? What altitude are you at? Sounds really lean. When I had my Toomey on, with FMFs, at sea level, I ran a 330 main, and it was on spot, plug chop was perfect. Quote Link to comment Share on other sites More sharing options...
Yamashee1 Posted September 7, 2006 Report Share Posted September 7, 2006 (edited) yeah, the Polarises are slow, that auto tranny really kills 'em too. Your running a 280 main, with an open filter and rocket pipes? What altitude are you at? Sounds really lean. When I had my Toomey on, with FMFs, at sea level, I ran a 330 main, and it was on spot, plug chop was perfect. Man I live here in Ft,Worth Texas Im not sure of the Altitude. It is Kinda hard to start at first. But then it Screams when it Warms up.if I am at sea level Should i Run 330 mains to? I have Heard alot of People say that they Ran 300 or Bigger.maybe I'll just buy a few sets of mains and see what works best. I mean my shee doesn't Bog when I gas it. it has Great Throttle Responce all the way to WOT. But im no Expert.I just Found Out That im at 670 Feet above sealevel. Edited September 8, 2006 by Yamashee1 Quote Link to comment Share on other sites More sharing options...
91-421 Posted September 8, 2006 Report Share Posted September 8, 2006 Man I live here in Ft,Worth Texas Im not sure of the Altitude. It is Kinda hard to start at first. But then it Screams when it Warms up.if I am at sea level Should i Run 330 mains to? I have Heard alot of People say that they Ran 300 or Bigger.maybe I'll just buy a few sets of mains and see what works best. I mean my shee doesn't Bog when I gas it. it has Great Throttle Responce all the way to WOT. But im no Expert.I just Found Out That im at 670 Feet above sealevel. So have you even checked your plugs? Quote Link to comment Share on other sites More sharing options...
Banshee4Drag Posted September 17, 2006 Report Share Posted September 17, 2006 Hey man, all the mods you have are for LOW end woods ridein...ditch the FmF thats about the worest pipe to run for a bike tha comes out of the woods...Tire/tire wieght makes a big diff... But anyways i have a set of T-5s for sale...all springs brackets stingers. are there in good shape... 210% and there are yours.... e-mail me back banshee4drag@hotmail.com Quote Link to comment Share on other sites More sharing options...
