Stock Shock Adjustment?
kb01shee
You can do it without lifting the bike with a flat head and a hammer.... What you'll want to do is back the top nut off about 3-4 threads... then spin the bottom one until it meets back up with the top one... then tighten the lock nut(top one) back down....
Mike
i was unable to adjust the rear shock with a channel locks. i was able to adjust the preload with a chisel and hammer however at the incredibly slow rate it was going, it would have taken a good hour or more because there is no ROOM around the rear shock. i ended up taking the shock off and clamping it in a benchtop vise to adjust the spring preload.
it only took about 15 minutes.
