bodge Posted April 11, 2006 Report Share Posted April 11, 2006 am i best of fitting a wider axle for road use and a bit of of road use and if i do should i fit some front wheel spacers or do i have to fit front arms?or can i just fit a rear axle? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 11, 2006 Report Share Posted April 11, 2006 Do you ride tight trails? No...keep it stock width? If you ride fast open trails, dunes, etc....then widen her up. Do a search on front rim swap...you can gain 3 to 4 inches of width up front without spending more than 20 bucks... Pair that with a +4 rear axle and it sure is nice in the turns. Quote Link to comment Share on other sites More sharing options...
bodge Posted April 11, 2006 Author Report Share Posted April 11, 2006 Do you ride tight trails? No...keep it stock width? If you ride fast open trails, dunes, etc....then widen her up. Do a search on front rim swap...you can gain 3 to 4 inches of width up front without spending more than 20 bucks... Pair that with a +4 rear axle and it sure is nice in the turns. 500608[/snapback] Hi im going to use it mostly on the road and the od trail. So a rear axle would be a good idea then. buy rim swap do you mean new rims and wider tyres or turning the rims round? thanks Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 11, 2006 Report Share Posted April 11, 2006 Turning the front rims around. You have to plug the old valve stem hole (so it doesn't hit the brake componenets) and drill a new hole in the opposite side of the rim. That is the cheap, easy man's way....it will stress out the front end a little more. The next thing is buy new rims with an offset... The best idea is longer A Arms and longer shocks...but, that's big bucks... Quote Link to comment Share on other sites More sharing options...
Wallrat Posted April 11, 2006 Report Share Posted April 11, 2006 Oh yeah and try to keep the front end just slightly wider than the rear or handling goes to shit. Quote Link to comment Share on other sites More sharing options...
ellison445 Posted April 11, 2006 Report Share Posted April 11, 2006 IM lost on what your trying to do am i best of fitting a wider axle for road use and a bit of of road use and if i do should i fit some front wheel spacers or do i have to fit front arms?or can i just fit a rear axle? 500599[/snapback] Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 11, 2006 Report Share Posted April 11, 2006 No shit...Ellison. Punctuation is such an aggravation..huh? Quote Link to comment Share on other sites More sharing options...
ellison445 Posted April 11, 2006 Report Share Posted April 11, 2006 Your better than me, looks like you helped him out No shit...Ellison.Punctuation is such an aggravation..huh? 500624[/snapback] Quote Link to comment Share on other sites More sharing options...
bodge Posted April 11, 2006 Author Report Share Posted April 11, 2006 The keyboard does seem a bit blurred after 20 pints of stella but i understood my question. Lets try to re word my question I have a brand new banshee, I will be using it for road use mainly and a bit of trails. Do you recommend that i fit a wider back axle? Can i just fit a back axle and leave the front wheel base standard? If i don't want to fit front arms can i fit some wheel spacers? Basically I want to make the shee as safe as possible for road use without spending to much money. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted April 11, 2006 Report Share Posted April 11, 2006 The keyboard does seem a bit blurred after 20 pints of stella but i understood my question. Lets try to re word my question I have a brand new banshee, I will be using it for road use mainly and a bit of trails. Do you recommend that i fit a wider back axle? Can i just fit a back axle and leave the front wheel base standard? If i don't want to fit front arms can i fit some wheel spacers? Basically I want to make the shee as safe as possible for road use without spending to much money. 500638[/snapback] If you dont ride any tight, technical trails, i'd definately recommend a wider axle and some a-arms. Flip your front rims around and save up some money and get the a-arms. Definately the way to go. You can get a used set from someone here or e-bay. Quote Link to comment Share on other sites More sharing options...
bodge Posted April 12, 2006 Author Report Share Posted April 12, 2006 If you dont ride any tight, technical trails, i'd definately recommend a wider axle and some a-arms. Flip your front rims around and save up some money and get the a-arms. Definately the way to go. You can get a used set from someone here or e-bay. 500689[/snapback] Thanks for the reply, i will do just that. Quote Link to comment Share on other sites More sharing options...
