Questions on Sprockets?
Im running stock 14 41 sprockets. Went to a taller tire. Guys at Cascade said instead of going to a 13 in the front go to a 43 in the back. If I understand right they said the less teeth the less it has on the chain??? I strickly only ride dunes. Im running fatty's, reeds, Pods, 4" extended swingarm, Big bore, carbs etc. I went from a 9 paddle hauler to a 9 paddle extreme.thanks
-1 tooth in the front equals +3 on the rear. Its really up to you whether you want to run a 13 or a 43. I guess I could see there point in having more surface in contact w/ the chain on really high HP bikes, but you should be able to run that 13 no problem. Half the banshees at glamis are running a 13 up front w/out any problems.
Maybe their real reason is that rear sprockets are more $$$
