nutcase Posted March 26, 2006 Report Share Posted March 26, 2006 I bought lonestar a arms off of ebay.They are the +2 +1. When i went to put them on i noticed that the bottom of the hubs are kicked out as far as they will go and the tops are kicked in as far as they will go.What am i doing wrong here.The top a arms are lick 3 inches shorter than the bottoms.Do i have to get different balljoints with longer threads to correct this? Quote Link to comment Share on other sites More sharing options...
nutcase Posted March 26, 2006 Author Report Share Posted March 26, 2006 I figured it out Quote Link to comment Share on other sites More sharing options...
txblueshee Posted March 26, 2006 Report Share Posted March 26, 2006 You want to dial iin your caster/camber with someone close to your weight sitting on the bike... I can't remember the excact numbers for the adjustments... I know there on the forum somewhere though.... Mike Quote Link to comment Share on other sites More sharing options...
wesw Posted March 26, 2006 Report Share Posted March 26, 2006 use a lever to get them some what close trust me its a major bitch that and tie rods Quote Link to comment Share on other sites More sharing options...
thack Posted May 10, 2006 Report Share Posted May 10, 2006 (edited) lsr recomends these settings caster positive camber negative motocross 4.5 degrees 4.5 degrees cross country 4.5 degrees 4.5 degrees sand dunning 3 -4.5 degrees 2-4 degrees recreational3.5-4.5 degrees 1-3 degrees desert racing6.5 degrees 2-4 degrees tt racing 3-4 gegrees 1 degrees caster left side camber right colum Edited May 10, 2006 by thack Quote Link to comment Share on other sites More sharing options...
