slowpokebanshee Posted March 25, 2006 Report Share Posted March 25, 2006 lookin to do a rebuild this summer, got about $800-$1000 to work with looking at cub cylinders, or a 4mil stroker crank. with porting on stock cylinders... also thinking about the "trinity" style 2:1 carb 35 or 38mm? currently stock motor with stock carbs t-5s K&N clamp ons milled head +7 timing plate...going after my brother he has stock stroke, huge drag porting, CPI pipes and 34mm carbs....milled head, and timing plate +4.... Quote Link to comment Share on other sites More sharing options...
dtm03 Posted March 25, 2006 Report Share Posted March 25, 2006 I'd probably go with the cubs. just because when you decide to go bigger, you have a better chance at selling the cubs than the stock cylinders..... but I dont think $800 - $1000 is gonna cover all of the cost of either of the two.... Quote Link to comment Share on other sites More sharing options...
wesw Posted March 25, 2006 Report Share Posted March 25, 2006 for the most power buy both cubs adn a crank would be pretty mean then Quote Link to comment Share on other sites More sharing options...
rocketboy Posted March 25, 2006 Report Share Posted March 25, 2006 (edited) i have a 65mm cub and would feel confident going up against any stock set of jugs on a 4mil l crank ,gotta ask yourself do yo u want low-midrange torque or screaming topend torque , like others have said... it takes alot more than 800$ to setup either package correctly Edited March 25, 2006 by rocketboy Quote Link to comment Share on other sites More sharing options...
broke Posted March 25, 2006 Report Share Posted March 25, 2006 I'd go with the crank first. It will be easy to add the 4Mmil cubs later, it will not be easy to add the stroker crank to stock stroke Cub jugs. The crank won't give you the power the jugs will, but it's also only 1/3 the price. You are looking at a minimum of $1300-1500 for a complete top end. Quote Link to comment Share on other sites More sharing options...
