BLUE STREAK Posted March 22, 2006 Report Share Posted March 22, 2006 Looking to get some extra width. any one tride those wheel stud extenders if so any luck if not what els works good for cheep Quote Link to comment Share on other sites More sharing options...
txblueshee Posted March 22, 2006 Report Share Posted March 22, 2006 Well you can d/l google tool bar for free.. it comes with a spell check... from there type hooked on phonics... get that on order.. pass.. then come back and decipher your post into something half way legible.... Then we'll be more than happy to help you out... Mike Quote Link to comment Share on other sites More sharing options...
ellison445 Posted March 22, 2006 Report Share Posted March 22, 2006 haaaaaaaaaaa Well you can d/l google tool bar for free.. it comes with a spell check... from there type hooked on phonics... get that on order.. pass.. then come back and decipher your post into something half way legible.... Then we'll be more than happy to help you out...Mike 490740[/snapback] Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted March 22, 2006 Report Share Posted March 22, 2006 (edited) isn't there an age rstriction on this site like above 3rd grade. Hate to say it but I am glad my children can spell better than that 8 and 14 Edited March 22, 2006 by batoutofshell Quote Link to comment Share on other sites More sharing options...
1.6i Posted March 22, 2006 Report Share Posted March 22, 2006 ROFL!!!! thats cold... Quote Link to comment Share on other sites More sharing options...
pipebomb Posted March 22, 2006 Report Share Posted March 22, 2006 Brrrrrrr. I think the temp dropped about 15 degrees in here. Quote Link to comment Share on other sites More sharing options...
Old Two-Smoke Posted March 22, 2006 Report Share Posted March 22, 2006 if not what els works good for cheep 490729[/snapback] I think electric fence works good for cheep Quote Link to comment Share on other sites More sharing options...
gipperz Posted March 22, 2006 Report Share Posted March 22, 2006 Man thats funny, made my day. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 22, 2006 Report Share Posted March 22, 2006 (edited) Looking to get some extra width. Edited March 22, 2006 by Tim C Quote Link to comment Share on other sites More sharing options...
txblueshee Posted March 22, 2006 Report Share Posted March 22, 2006 You can flip your wheels around and gain some width - the rear are no problem but for the fronts you will have to put the valve stems on the opposite side of the rim so it don't rub.....just plug the existing hole by putting a valve stem in the opposite way. You will gain about 4" on the front and about 2 1/2" in the rear. This won't cost you anything except maybe the cost of remounting the front tires. 490873[/snapback] Not to mention the fact it'll handle like snot covered shit.... Scroll down to the bump steer thread... then scroll down to the custom axis thread.... By then you should realize just save your money and do it right the first time... Been there, done that... Doing anything to the front end shy of a set of good tires and shocks is a waste of money.... Mike Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 22, 2006 Report Share Posted March 22, 2006 Not to mention the fact it'll handle like snot covered shit.... Scroll down to the bump steer thread... then scroll down to the custom axis thread.... By then you should realize just save your money and do it right the first time... Been there, done that... Doing anything to the front end shy of a set of good tires and shocks is a waste of money....Mike 490877[/snapback] I ran mine stock rims flipped for a while and never had a problem. Wider A-arms don't fix the bump steer problem - a narrower frame where A-arms attach to does so the tie rods and arms travel on the same plane. Quote Link to comment Share on other sites More sharing options...
txblueshee Posted March 22, 2006 Report Share Posted March 22, 2006 I ran mine stock rims flipped for a while and never had a problem. Wider A-arms don't fix the bump steer problem - a narrower frame where A-arms attach to does so the tie rods and arms travel on the same plane. 490930[/snapback] Flipping your front rims will give you more bump steer than shitty a-arms ever thought of.... Also... I nice set of a-arms will also cure a little bit of bump steer.... The average rider Ie: The people that run wheel spacers, wider offset rims or flipped fronts wouldn't even notice the bump steer in stock form.... but it's there.... an by fucking up and already fubared bike as far as suspension geometry goes it throws the whole train off the track.... Mike Quote Link to comment Share on other sites More sharing options...
BLUE STREAK Posted March 22, 2006 Author Report Share Posted March 22, 2006 hay mike last time i checked the google tool bar fubared is not a word but I think you would know that seeing as your expert. could you put some pants on or did your diaper fall off . thanks gang Quote Link to comment Share on other sites More sharing options...
racer Posted March 23, 2006 Report Share Posted March 23, 2006 hay mike last time i checked the google tool bar fubared is not a word 491138[/snapback] its an acronym technically. a word created from the first letter in a string of words. like SWAT, or SEALs Quote Link to comment Share on other sites More sharing options...
txblueshee Posted March 23, 2006 Report Share Posted March 23, 2006 its an acronym technically. a word created from the first letter in a string of words. like SWAT, or SEALs 491274[/snapback] ...... Mike Quote Link to comment Share on other sites More sharing options...
