pipebomb Posted March 18, 2006 Report Share Posted March 18, 2006 Q: I've just modified my engine and need to rejet my carb. How do I find my Elevation/Altitude?? A: If you've done work to your motor or going to ride in a place different from your normal spot, chances are your may need to tune your carb(s) to match the difference in elevation change between the 2 places so the motor will preform properly. This link will take you to a site where you can look up where you are or where your are going. this can allow your to make any neccessary adjustments to your jetting. http://www.topozone.com/ Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted March 18, 2006 Report Share Posted March 18, 2006 Q: I've just modified my engine and need to rejet my carb. How do I find my Elevation/Altitude?? A: If you've done work to your motor or going to ride in a place different from your normal spot, chances are your may need to tune your carb(s) to match the difference in elevation change between the 2 places so the motor will preform properly. This link will take you to a site where you can look up where you are or where your are going. this can allow your to make any neccessary adjustments to your jetting. http://www.topozone.com/ 488776[/snapback] lokk at a rand mcnally map at the truck stops if you don't have one they show it or look it up on the web!! your area* elavation key words Quote Link to comment Share on other sites More sharing options...
pipebomb Posted March 18, 2006 Author Report Share Posted March 18, 2006 (edited) I know that too, but you'd be suprised how many times I've been asked about jetting and the person has no idea where the hell they are. which gets a groan and a roll of the eyes from me. and thats when i send them this and say, "here, look it up and get back to me." Edited March 18, 2006 by pipebomb Quote Link to comment Share on other sites More sharing options...
mondtster Posted March 18, 2006 Report Share Posted March 18, 2006 An even easier way is to use a GPS if you have access to one. I found that I was actually several hundred feet higher than what was claimed by all the other information I had access to. Quote Link to comment Share on other sites More sharing options...
