banshee_08 Posted March 28, 2006 Author Report Share Posted March 28, 2006 well it only does it when the clutch is out and the noise is comin from the left side isnt that the side the clutch is on? im new to this shit sorry for bein a dumass Quote Link to comment Share on other sites More sharing options...
banshee350twin Posted March 29, 2006 Report Share Posted March 29, 2006 Clutch is on the right side. Mine is doin the same thing ur's is. Quote Link to comment Share on other sites More sharing options...
banshee350twin Posted March 29, 2006 Report Share Posted March 29, 2006 Im sendin my motor to passion. So i gotta wait to get it fixed. Quote Link to comment Share on other sites More sharing options...
80overShee Posted March 29, 2006 Report Share Posted March 29, 2006 Clutch is on the right side. I'm with everyone else on this one. Check the clutch and all clutch parts over with a fine tooth comb. Pull the clutch rods and ball inside the shaft the clutch is mounted on as well. Check them for wear. They can seize up if they don't get proper lube. Check the kicker gear and idler gear. If the snap ring came off it can cause strange noises. Happened on mine. Sounded just like a ball bearing being tossed around inside the clutch cover. The only other thing that could cause the noise is the bearings that the transmission shafts run on but those really shouldnt be affected by tension on the clutch, they constantly spin. Its really not that difficult to split the cases. I was a little weary of it the first time I did it also, no I practically enjoy it. Other than for the fact that there is a REASON I have to which normally means $, thats a downer. I wouldn't advise it if you aren't confident in your abilities but its really not that scary if you sit down and look at it. If you say your brother can do it, help him! Watch him, you should know how to fix your own toys. That dealership is going to charge you mega-moola. The ones around here charge $75 just for a rejetting and they don't even check to make sure its right, they guess. Im gonna bet it will be atleast $250 if its not something extraordinarily simple. Quote Link to comment Share on other sites More sharing options...
banshee350twin Posted March 29, 2006 Report Share Posted March 29, 2006 Yea when i spin the clutch basket it sound's like alittle ball rolling around. Quote Link to comment Share on other sites More sharing options...
DaFish Posted March 29, 2006 Report Share Posted March 29, 2006 ive had a whinning noise ever since mine was brand new so i don't know and everthing works fine Quote Link to comment Share on other sites More sharing options...
banshee350twin Posted March 29, 2006 Report Share Posted March 29, 2006 Well mine is pritty bad. If ur's sound's like that brand new i wouldnt ride it lol. Quote Link to comment Share on other sites More sharing options...
Wicked98Shee Posted March 29, 2006 Report Share Posted March 29, 2006 most likely the clutch as everyone has said ... trans and clutch work on a shee is really simple.. my 03 has made a wierd knockin noise since it came home from the stealership, i was around back when the rz's 1st came out and we all know theyre basicly the same and i gotta say they are the noisiest obsene soundin trans around .. most noises in a banshee trans are the nature of the beast Quote Link to comment Share on other sites More sharing options...
banshee350twin Posted March 29, 2006 Report Share Posted March 29, 2006 well mine never made the noise. So that tell's u there is something wrong. TWIN Quote Link to comment Share on other sites More sharing options...
