Spark Plugs backing out
finman
Is there a trick to keep the spark plugs from backing out? They seem to back out quickly. I have them pretty snug not super tight. I dont want to strip out the head.
They should not back out, are you using a stock head?
if so you may be getting slight detonation.
Need mroe info, like type of head, Compression, altitude, and temp.
486258[/snapback]
sorry I thought the info was in my profile.
2002 banshee, cool head,18 domes, +4 crank, sand port, 110 octane fuel.
Sea level in Oklahoma.
Thanks,
Finman
Which Cool head?
it could be something like a dome being loose in the head, I got a bad dome a while back and it caused my sparkplugs to back out. The domes were about 1000th of an inch off.
Otherwise your detonating.
My guess is detonation, how much compression do you have?
I run 19CC domes at sea level but my compression is lower due to porting. I mix 50/50, if I was to drop to 18 I would have to run 110, but again I have porting so my compression is only 170.
Edited by Justintoxicated
Doesnt matter if he is running 118 ...... If its backing plugs out , He has detonation trouble from what i have seen. Better get to checking for an air leak or a lean condition !!!
is there something I should look for on the spark plug to see if detonating?
486277[/snapback]
useually spotting.
dont get the plug lock, the plugs backing out is the only thing saving your motor!!!!
you go locking the plugs down and it will blow sky high! check your jetting first. I thought I was good with the jetting I had and it backed the plugs out a time or two. ended up jumping up like two or three jet sizes before it was were it needed to be.
I pulled the plugs and they are a little light brown.
I will double check the jets and buy new plugs and make sure I get them in there pretty snug.
Will let you know.
Thanks,
Finman
486583[/snapback]
What recommendations would you have for main jet?
I have no advanced timing, lid off air box, pro design foam filter/cool head, +4 crank, 110 octane fuel, stock carbs, CPI pipes
Finman
What kind of porting? Always recommend to ask who ported what jets first!
We have had them from 320 -440 on stock carbs. Depends on the port work.
I would GUESS around 360-380 range should be safe! Always start rich and come down.
