yeah the best liquid performance that i've found is a nifty product called B.E.E.R. You can actually get it at a lot of places, even corner stores. It's an amazing product, and can boost performance drastically! It works so well, the government in the US won't let anyone under 21 use it!!! :blink: It is very similar to Liquid Courage, which is another awesome product.
  • 1 month later...
I too like engine ice. I just recently switched over too it and noticed a 15 degree drop in temp. You get rid off all the coolant in the bike and run it straight with no water. You will need two jugs of it. Can't comment on the other stuff never used it.
I've been using it (engin ice) for a couple years, and noticed my banshee running alot cooler since...good stuff.
My local Yamaha dealer sells it.
IDK about Liquid Performance, never used it.
engine ice is only a glycol blend- same as that which is used in RVs because its bio-degradable only it has another additive which is basically water wetter (like soap)which breaks the surface tension of the liquid and allows it to release air molecules trapped against metal surfaces.
