wider front end
There aint no problems i have wheel spacers on my blaster i used to jumb it all the time and they have bean on sence prolly i was almost 14 im 15 now an id go like a bastard threw the badass trails up in maine with my buddies on the back so ur will be ok nik
Are they any common problems with using wheel spacers? anything i should be concerned with?
I dont want to flip my wheels around simply beacause i dont want to permantly mod them, thats all.
485289[/snapback]
What's a permanent mod? You're drilling two holes, that's it.
If you don't like it...or want to switch 'em back, just pop for 4 new valve stems....
I gaurentee it's cheaper than new rims and wheel spacers...and most definately more reliable than spacer kits...
Believe me...once you swap the front rims, you won't go back...
485313[/snapback]
What do you do about the original holes??? How do you plug them easily... I was thinking of doing that but I was gona get the original holes welded up.
Ruko, put valve stems in the orig. holes upside down.
Ive had my wheels like this for a few years. It did widen the track to match my +4 rear axle. But it puts a lot more leverage on everything including your hands/arms. Ive bent 2 spindles, and you will feel it when you go through ruts or hit rocks, like I said it puts more stress on everything.
I dont want to swap them back and loose the width, so I am going to try widening my stock aarms for +2 and flipping the wheels back so I will have no ill side effects of offset wheels/spacers.
485327[/snapback]
He is exactly right....it will stress out the front a little more, of course...that depends on where you ride, too. I don't do tight trails or real rocky/bumpy/muddy riding...more or less fast open trails, drag racing or dunes...
Wider A Arms are definately the way to go...but, you're talking a few hundred bucks now...too...
