Dyna Tek FS CDI ?
i have a dyna.
personnally i wonder if they are worth much.
if you need or want a fancy timing curve im sure they would be the cats meow.
my dyno place tried several curves and got nothing impressive from them.
just my thoughts
I would answer the question, but I can't think with all the boobs in my face....
Anyway from what I have seen the dyna's are nice cause you can create custom curves, and it puts out more sparking energy then the stock cdi. On some bikes this is good and some it makes no difference. Basically the dyna's programability allows more precise ignition advance, then just adjusting a timing plate. The extra spark energy only really seems to help on high horse power engines that are feeding a lot of air and fuel into the cylinders.
Also I have seen a few rare instances where a bike had a miss to it no matter what was done. Tried everything to fix it and the only cure was a dyna cdi box. Still can't figure out why it won't run with out a dyna cdi.....
