broke Posted February 24, 2006 Report Share Posted February 24, 2006 The last time I had this out, it ran great, then the clutch started to fade. Within a few miles the clutch locked up completely. I had to start it in gear and drive back to the truck. I originally thought the rod and ball had become one. When I pulled it apart, everything looks fine. The only thing that even shows that anything happened is you can see some serious blueing on the steels from the heat. The entire motor only has about 4 hours on it. Has anybody had there steels "feel" like the seized to the fibers, I pretty much had to peel the whole stack apart. I've never seen anything like this. Quote Link to comment Share on other sites More sharing options...
daryn c Posted February 24, 2006 Report Share Posted February 24, 2006 get new plated , springs , and if your cable fron ur lever to it is hard then replace that ... Quote Link to comment Share on other sites More sharing options...
broke Posted February 25, 2006 Author Report Share Posted February 25, 2006 Fibers, steels, springs and cable were all new when the motor was built. They have about four hours on them total. I don't mind buying new parts, but I would at least like to figure out what cooked these ones first. I would hate to burn through $100 in clutch parts every 4 hours constantly. Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted February 25, 2006 Report Share Posted February 25, 2006 not sure what cooked them just make sure the adjustment screw in the center of the clkutch plate is adjusted right , maybe that has a factor with it ? just my 02 Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted February 25, 2006 Report Share Posted February 25, 2006 The freeplay might not been adjusted right on the cable. Quote Link to comment Share on other sites More sharing options...
scotts96fast Posted February 25, 2006 Report Share Posted February 25, 2006 Who's clutch are you running?I smoked a dirtdigger clutch in a afternoon and they where really black and blue,but not welded together like yours.I put a FAST clutch in,but didn't ride yet. Like said above if the freeplay was out of wack,or worn inner hub and prussure plate with new clutches that could be a problem. Quote Link to comment Share on other sites More sharing options...
broke Posted February 25, 2006 Author Report Share Posted February 25, 2006 It is a FAST clutch. Free play was at least the minimum amount. Arrows ligned up between the cases and clutch arm. I am kind of leaning toward the worn pressure plate, the inner hub is new. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted February 25, 2006 Report Share Posted February 25, 2006 (edited) I had this problem once, I put a brand new clutch in from duncan racing and the clutch started hanging up on me. So I went through the clutch again and readjusted everything again and It still did it. I took out the new duncan clutch and put in my old dirt digger and it still did it.. by this Time I was gettin pissed. I made some calls and it turns out it was my new clutch perch and lever.. I bought a magnum EZ pull lever and perch and I guess the universal design dosn't have the correct pull. I put my stock perch back on and it worked perfect again... dont know if you changed the perch recently but this was my problem Anyone try the ASV perch and lever sets? Edited February 25, 2006 by fouledout2 Quote Link to comment Share on other sites More sharing options...
Old Two-Smoke Posted February 25, 2006 Report Share Posted February 25, 2006 You dont say if your running a high HP engine or not. What oil are you running? If it was new and wasnt properly oil soaked to start with, you most likely smoked it right away and after that it gave up all together..Also make sure the pressure plate isnt warped.. Quote Link to comment Share on other sites More sharing options...
lowriderb Posted February 25, 2006 Report Share Posted February 25, 2006 is the clutch basket grooved or anything as well? Quote Link to comment Share on other sites More sharing options...
grounded Posted February 25, 2006 Report Share Posted February 25, 2006 I run the ASV set up no problems at all here. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 25, 2006 Report Share Posted February 25, 2006 It is a FAST clutch. Free play was at least the minimum amount. Arrows ligned up between the cases and clutch arm. I am kind of leaning toward the worn pressure plate, the inner hub is new. 478609[/snapback] broke, give me a call and i will help you get it figured out!! Quote Link to comment Share on other sites More sharing options...
Wallrat Posted February 25, 2006 Report Share Posted February 25, 2006 I smoked a brand new dirt digger in about 6 hours so it can happen. Replaced it and seems to be working fine. Quote Link to comment Share on other sites More sharing options...
broke Posted February 25, 2006 Author Report Share Posted February 25, 2006 Thanks for all the responses. You dont say if your running a high HP engine or not. What oil are you running? If it was new and wasnt properly oil soaked to start with, you most likely smoked it right away and after that it gave up all together..Also make sure the pressure plate isnt warped.. It's a 12 port +4 RZ motor. Not real high performance, but not stock either. I would guess it around 70hp give or take a few. is the clutch basket grooved or anything as well? It's lightly grooved, but it may be time to just bite the bullet and get a billet one. Quote Link to comment Share on other sites More sharing options...
