rear shock sag
MILO
i noticed that my shee sags a little with no additional weight on it, just sitting in the garage. i mean, i can pick it up about 1/2" from it's normal sitting height before it tops out. my nephew's blaster isn't like that, it's pretty rigid. is that normal or is something starting to go on it? also when i sit on it it drops about 4", it shouldn't be more than about 3" right? i'm gonna bump up the preload for rider sag, but shouldn't it be topped out with no rider?? :confused:
i worked on the preload some and got it to where it only sags about 3 1/4" with me on it. if i understand this correctly, with the wheels off the ground the spring length should be no shorter than 8 7/16", at least by my clymer's. and that's where it's at now, so that means i'm out of preload adjustment, right? :confused:
adjusting definitely helped with the 1/2" sag with just the shee itself, the rest of it is from some play in the linkage bushings, which i have new stuff to replace it with.
so is the 3 1/4" sag with rider on sound about right, or am i in for some shock or spring work to get it any better?
