williamjernigan Posted February 13, 2006 Report Share Posted February 13, 2006 OK I have my tecate wich I am installing a 44 lectron on as soon as it gets warm so that I can run methonol. I will run it into the side of the reed cage. If I wanted to also have nitrous with it how would I hook it up. Would I run dry into the airfilter or wet with the alcohol somehow? If anyone has done this or knows someone who has done this please give some advice. I only want to run a 9 or 12oz bottle with about a 10 or 15 horsepower shot. Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted February 13, 2006 Report Share Posted February 13, 2006 I would fab up a 1/2" spacer plate and mount your nozzle in it, or if you have a billet intake mount the nozzle there. As for the fuel question, I run a wet system on my banshee, I run alky thru the carbs and spray mixed gas with the nitrous. Mount your nozzle in between the carb and reeds, I am not sure how well it would work otherwise. It would most likely blow out your reeds. I fabbed a small aluminum tank for my gas that I spray with the nitrous. A couple things to think about. Stay away from carbon fiber reeds, they tend to freeze and break. And you will need to retard your timing when spraying,I have found 1.5 degrees retarded for every 10 horse shot seems to work well. I have a NX kit and it is a very nice setup. Quote Link to comment Share on other sites More sharing options...
blackstallion Posted March 8, 2006 Report Share Posted March 8, 2006 I would fab up a 1/2" spacer plate and mount your nozzle in it, or if you have a billet intake mount the nozzle there. As for the fuel question, I run a wet system on my banshee, I run alky thru the carbs and spray mixed gas with the nitrous. Mount your nozzle in between the carb and reeds, I am not sure how well it would work otherwise. It would most likely blow out your reeds. I fabbed a small aluminum tank for my gas that I spray with the nitrous. A couple things to think about. Stay away from carbon fiber reeds, they tend to freeze and break. And you will need to retard your timing when spraying,I have found 1.5 degrees retarded for every 10 horse shot seems to work well. I have a NX kit and it is a very nice setup. 472918[/snapback] your running gas with the alcohol is the right way. ive heard of guys with what your talking about freezing the reeds im runnin carbon fiber v force on mine never had a problem whatso ever like that. wiht the timing i run 5 degrees on spray and you dont have to retard it till after 50hp that was the words straight from NOS. i sprayn 80 through mine runnin 4 degrees timing wiht 19cc domes on 110 race gas. buddy of mine runs his on alcohol and mixes the gas for the nitrous like you were saying Quote Link to comment Share on other sites More sharing options...
korndawg Posted March 8, 2006 Report Share Posted March 8, 2006 You might check with these guys for any questions you have on the nitrous. http://www.boondockers.com/site.htm Quote Link to comment Share on other sites More sharing options...
