locogato11283 Posted February 12, 2006 Report Share Posted February 12, 2006 It's going to require you to put spacers on your right foot peg to clear the extended cover. This also means longer bolts on the peg. I also had to tweak the brake pedal to work well with the wider cover. you dont need spacers. i dont run spacers on mine. just tweaked the brake pedal a little bit. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted February 12, 2006 Report Share Posted February 12, 2006 you dont need spacers. i dont run spacers on mine. just tweaked the brake pedal a little bit. 472434[/snapback] same here,no spacers just tweaked brake pedal a little Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 12, 2006 Report Share Posted February 12, 2006 same here,no spacers just tweaked brake pedal a little 472454[/snapback] I also did not use any spacers. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 12, 2006 Author Report Share Posted February 12, 2006 Spacing or tweaking the peg will be no problem at all. Ok...and thanks for all your input by the way...two more questions. 1. Who/where/how much $$ does it cost for a modified side cover or aftermarket side cover and... 2. Does it really make it shift worse? Again...I'll probably dune and play drag with my buddies most of the time. But...I plan on running some open and fast trails. however...I don't want to have to kill meself shifting this baby.... I do like the non-HD clutch spring ideas I've heard...Popeye forearms I have not...(yet... ) Thanks again...lads. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted February 13, 2006 Report Share Posted February 13, 2006 it usually costs around 175.00 and up depending on where you have it done.i run a lockup on my clutch and it shifts great with it but then i run an overide tranny .squeezing the clutch is no different with the lockup then it is without it and i would reccomend you just run the stock springs. Quote Link to comment Share on other sites More sharing options...
bkabina Posted February 13, 2006 Report Share Posted February 13, 2006 The older style lock-ups used a spacer on the foot peg.The new styles don't use any spacers.Regular riding with a lock-up is no different,shifting and clutch pull will be the same.They cover and lock-up will probably start around $325. but it depends on if you use a core or if you want it polished.Just shop around,most any builders can get them for you.Feel free to PM me if you have any questions or need help. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 13, 2006 Report Share Posted February 13, 2006 1. Who/where/how much $$ does it cost for a modified side cover or aftermarket side cover and... 472495[/snapback] FAST usually has them in stock.. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 13, 2006 Report Share Posted February 13, 2006 Quote Link to comment Share on other sites More sharing options...
DaFish Posted February 13, 2006 Report Share Posted February 13, 2006 I play drag with my buddies most of the time 472262[/snapback] do you really, i think you should change your name to RumpRanger so every could call you rr for short have fun with your "buddies" Quote Link to comment Share on other sites More sharing options...
Brooke Posted February 13, 2006 Report Share Posted February 13, 2006 do you really, i think you should change your name to RumpRanger so every could call you rr for short have fun with your "buddies" 472679[/snapback] how bout if everyone calls you DaFaag from now on? everyone in favor say DAFAAG!!! Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted February 13, 2006 Report Share Posted February 13, 2006 how bout if everyone calls you DaFaag from now on? everyone in favor say DAFAAG!!! 472701[/snapback] good one brooke Quote Link to comment Share on other sites More sharing options...
Ls7colorado Posted February 13, 2006 Report Share Posted February 13, 2006 I see now! looks like a very effective way to add more holding pressure without having stiffer springs/exspensive clutches.... O yall already knew that........ Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 13, 2006 Author Report Share Posted February 13, 2006 do you really, i think you should change your name to RumpRanger so every could call you rr for short have fun with your "buddies" 472679[/snapback] Damn it...I actually had to read that shit another time and let it soak in. Good one...very funny... I owe you one...no doubt. Play DRAG RACE.... Is that better? As in play drag race our quads.... Silly sick fuck. Anyways...Jeff...I'll talk apples with you when I call you for my motor items. I'm going to decide weather I get a new basket, plate, etc....or go with a lockup. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted February 13, 2006 Report Share Posted February 13, 2006 how bout if everyone calls you DaFaag from now on? everyone in favor say DAFAAG!!! 472701[/snapback] LMFAO Using 3 stock springs and 3 HD springs the pull on the clutch is not bad at all. Shifting is no different than it is using a stock setup, the only thing that changes really is the fact that your clutch isn't slipping...If you're running over 70hp, and plan to drag race a lot, the lockout is a good investment IMHO Here's some more visual incentive for you. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted February 13, 2006 Author Report Share Posted February 13, 2006 Damn...that sure is purdy... I'm hoping to be over 70 with cubs and a 4 mil.... I run Jeff's clutch, 3HD springs and 3 stock springs now with an easy clutch lever...it's not bad at all. Seriously...that's a good looking setup you got there.... Quote Link to comment Share on other sites More sharing options...
