neddle and VALVE, THROTTLE
The first thing that pops into my mind is that the slides are reversed. This would not be affected by either needle, otherwise I would wonder if the needle was not correct for the app. Check the slides for starters. Otherwise check the cable and then watch the needle through the back of the carb to make sure it is lining up with the main jet bore.
dude...
the slided are in the wrong carbs....
been there before..........make sure the to look in the air box to see the curved side of the slide is facing the intake ............and in sink too
pm if ya need more help
and have a beer.......it makes it easier to fix
heehee
471814[/snapback]
i did them seperate
