Bansheerider29x Posted February 2, 2006 Report Share Posted February 2, 2006 I have a barnett dirt digger clutch kit with everything else on the clutch being stock. Im going to be getting a 4mm stroker kit with a new top end and a pretty big port. I need the specs to find out if my plates are still good. They look good on everything with no discoloration but i dont wanna put my clutch back together then blow the clucth once its rebuilt and have to get a new one. does anyone have the specs for the dirt digger kit and is the specs same as stock or the fzr400 street bike? because i have specs for the fzr400 but idk if they are the same. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted February 2, 2006 Report Share Posted February 2, 2006 I've heard that the dirt digger is only good up to about 60HP or so. I put a brand new DD in my stroker and it didn't hold. Quote Link to comment Share on other sites More sharing options...
Bansheerider29x Posted February 3, 2006 Author Report Share Posted February 3, 2006 bump Quote Link to comment Share on other sites More sharing options...
Wallrat Posted February 3, 2006 Report Share Posted February 3, 2006 I think I solved your issue so why the bump? Regardless of specs, a BRAND NEW dirt digger won't work for you. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 3, 2006 Report Share Posted February 3, 2006 FAST clutch..those barnett ones arent gonna hold up to a stroker motor.. Quote Link to comment Share on other sites More sharing options...
Bansheerider29x Posted February 3, 2006 Author Report Share Posted February 3, 2006 I see barnett's all the time on 4mil stroker kits though. How much will a fast clutch cost? also you said you heard that they were only good up to 60hp but are you sure? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted February 3, 2006 Report Share Posted February 3, 2006 FAST clutch..those barnett ones arent gonna hold up to a stroker motor.. 468286[/snapback] Bansheerider, give me a holler at the shop and i will get you any specs you need. We have replaced a bunch of failing Barnett clutch setups . As wallrat said they just dont seem to hold up well on a modified bike. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 3, 2006 Report Share Posted February 3, 2006 I see barnett's all the time on 4mil stroker kits though. How much will a fast clutch cost? also you said you heard that they were only good up to 60hp but are you sure? 468292[/snapback] i had a barnett clutch fail in a yfz450. no way would i attempt to put one in a stroker motor. y half ass it, do it right the first time... Quote Link to comment Share on other sites More sharing options...
