greg_banshee Posted January 29, 2006 Report Share Posted January 29, 2006 Hey guys just wondering what size domes to go with i'm almost at sea level here in Nova Scotia Canada & here are my mods ... UNI filter, Air Box Cut inside, TORS removed, FMF ram Valve Reeds & cages, Intakes are cut, head shaved .030", 280 mains, 40 pilots, Pro Circuit pipes. want to get a bit more power out of er, was thinkin 21cc domes with cool head or Noss head, & advancing the timming 4+ ? will it make that much of a difference to actually notice it ? Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted January 29, 2006 Report Share Posted January 29, 2006 Going from a cut head to a noss head with 21cc domesis about the same, you'll notice better cooling from the noss head. you'll have better low end from the timing plate at +4 degrees and it will work well with your other mods. best bang for the buck is porting,a good all around port job make the banshee so much easier to ride and alot faster. Quote Link to comment Share on other sites More sharing options...
greg_banshee Posted January 30, 2006 Author Report Share Posted January 30, 2006 Thanx for the info ! Quote Link to comment Share on other sites More sharing options...
