Can't pull A-arm Bolt Out?
KpnitG
Sound's like the bolt is bent, or a bad bushing in the A-arm. Any ways you should check it out after you get it out and replace the worn out part's. I would use some type of lube/spray to slick the process of removing this part. Also befor re-assembly check your zirk fitting to make sure it's not plugged up for Fu-maintance. :D
if it is seized in the sleeve it s not coming out, i cut the ends off with a cut wheel on a 4 inch grinder.pull the a arm out and trash whats left of the bolt and sleeve.e bay has the new parts you need, some hq`er gotta have a bolt and sleeve.
I agree with NYUK i had to do the same thing i cut both ends of the bolt off with a grinder and cut off wheel but then took the a-arm to a vise where icould get more room and really wacked the shit out of it with a really big hammer and it finally came out. Then i just ordered a new bolt.
