g-force Posted January 22, 2006 Report Share Posted January 22, 2006 should you have to re-jet after installing +4 timing plate? seems to hesitate off idle and then runs fine from mid to full. also is it normal for the kickstarter to kick back a little with advanced timing? Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted January 22, 2006 Report Share Posted January 22, 2006 Any jetting adjustments that youll need to make after timming changes probably existed before you changed your timming- timming should'nt effect jetting. At least it did'nt on mine... Quote Link to comment Share on other sites More sharing options...
sredish Posted January 22, 2006 Report Share Posted January 22, 2006 No changes will be necessary with timing changes alone. Also, if your going to make the change, go ahead and make it worthwhile; like +6. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted January 22, 2006 Report Share Posted January 22, 2006 (edited) if its kicking back a little on the kick starter the timing is probally advanced about all you wanna advance it.sounds to me like you might have it advanced a little to much.i'd try retarding it just a little bit. Edited January 22, 2006 by blueshee03 Quote Link to comment Share on other sites More sharing options...
rocketboy Posted January 22, 2006 Report Share Posted January 22, 2006 ive heard that banshee ignition timing is poorly and erraticly set and is often already advanced or retarded several degrees by flukes from the factory , get a light and time it and youd get many different readings on many unmodified banshees ,you may very wel l be much higheradvanced than you think ! dont know how true this is, but ive heard it man y times from many different reliable sources Quote Link to comment Share on other sites More sharing options...
g-force Posted January 22, 2006 Author Report Share Posted January 22, 2006 (edited) i found the problem, i took the flywheel off and found the key down on the bottom, it must of come off when i put the flywheel back on! i re-assembled everything and it runs great! thanks for the help. Edited January 22, 2006 by g-force Quote Link to comment Share on other sites More sharing options...
Malott 1 Posted January 22, 2006 Report Share Posted January 22, 2006 Did you use a advance key or adjustable timing plate? If you used the key you might want to look into getting a adjustable plate. Those keys have a bad habit of shearing off and you can pick the plates up real cheap. Quote Link to comment Share on other sites More sharing options...
floyd398 Posted January 24, 2006 Report Share Posted January 24, 2006 Does anyone lose any topend after going +4 or more on the timing. I've heard that the most noticable gains are low to mid with the timing advancement? I'm asking because I was gonna get the ricky stator plate but don't wanna lose anything on top. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted January 24, 2006 Report Share Posted January 24, 2006 Really depends on where your setting at compression wise when you make the advance. Generally no, you will gain throughout. Quote Link to comment Share on other sites More sharing options...
midnite Posted January 25, 2006 Report Share Posted January 25, 2006 Does anyone lose any topend after going +4 or more on the timing. I've heard that the most noticable gains are low to mid with the timing advancement? I'm asking because I was gonna get the ricky stator plate but don't wanna lose anything on top. 464151[/snapback] The 4 degree timing advance took 3 or 4 mph {on pavement} away from the top end on my 99. It's running a shaved head with 140 psi in both cylinders. With out the advance, my bike revs 500 rpms or more higher than with the advance. The benifit I got from the advance was out of the powerband {lower rpms}. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 25, 2006 Report Share Posted January 25, 2006 Mine kicks back every now and then as well. Never thought anything of it. Haven't had any problems with the shee up to this point, so I don't worry about it. Quote Link to comment Share on other sites More sharing options...
knight_ripper Posted April 17, 2006 Report Share Posted April 17, 2006 hahahaha...I just did the timing advance...and I almost broke my ankle trying to kick it with sneakers on. I just gave it a rap...and hell yes it kicked back. bruised my foot. LOL. I love this shit. Hopeing that I dont have to re-jet either....but Im going to do some plug work to find out. wish me luck. Quote Link to comment Share on other sites More sharing options...
Eazy Posted April 17, 2006 Report Share Posted April 17, 2006 Is there anything needed when doin' the install? Remove the flywheel (adj. timing plate), flywheel puller,etc?? Im thinkin' about doin' this mod..IS IT WORTH IT?? Quote Link to comment Share on other sites More sharing options...
DIRTMAN350 Posted April 17, 2006 Report Share Posted April 17, 2006 The timing plate mod is well worth it. You will need a flywheel puller. DO NOT use anything else or you will destry your flywheel. If you can afford to leave the shee down for awhile I would have boonman lighten up your stock flywheel. I wish i could leave mine down for him to lighten it. If you have access to a air impact it will make life easier. You can get a flywheel puller just about anywhere. Set your gap on your pick-up coil to .020". Quote Link to comment Share on other sites More sharing options...
