409Banshee Posted January 12, 2006 Report Share Posted January 12, 2006 As the title says. Boy am I pissed, but I guess this can be expected from a used machine. I took it apart, only to find this: all kinds of mismatched bolts, some are missing and the ones in place are not the right ones, engine is not what the seller said it was (it is a big bore, no stroker crank) carbs are ???? cuz I ordered a new cable from Rocky Mountain for stock carbs without TORS and it doesn't fit. The swingarm I believe is toast because I had to cut off the bolt from the insides of the frame on both sides, but now that piece that is still in the arm is stuck and will not come out. I heated up with MAPP gas and it did nada,and I don't want to break out the oxy acetylene torch cuz that will melt the swingarm. Anyone got an idea on how to attempt to try to get this bolt out? I have hammered away on this to no avail and I'm on my last nerve with this thing. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted January 12, 2006 Report Share Posted January 12, 2006 Shoot some panther piss in both sides, like WD-40, and let it set, then beat the shit out of it again. Sounds like it's probably rusted in place. If you have the swingarm out, you can put some diesel in a big pan, and stick the bolt end in the pan and let it soak. Might take a few hours or a few days, but I'm sure you're gonna have to get a BFH, and beat the crap out of it some more. Quote Link to comment Share on other sites More sharing options...
MILO Posted January 12, 2006 Report Share Posted January 12, 2006 maybe with an air hammer? or just keep pounding the shit out of it. i agree though, if you have it off, let it soak for a while first. if you get it out, a new bolt and bushings should be all you need. good luck. Quote Link to comment Share on other sites More sharing options...
409Banshee Posted January 12, 2006 Author Report Share Posted January 12, 2006 Fast: I've sprayed 1 can of WD, 1 can of PB Blaster and some stuff called Croil into this thing and it ain't working! I'll have to hijack some diesel from the shop. Doesn't hurt to try at this point. Been working on this for almost 2 weeks! Milo: You may be my savior! I forgot about that handy little tool. Will have to try that. Is it possible that something in there is bent just enough not to let that bolt out? Just my 2 cents, cuz who's to say that this wasn't crashed hard, fixed and put back together just to make a few $$$. Quote Link to comment Share on other sites More sharing options...
suzuki0702 Posted January 12, 2006 Report Share Posted January 12, 2006 get the torch out ..u can heat just the bolt just dont hit the O2 trigger! cherry it up then air hammer the sunbitch Quote Link to comment Share on other sites More sharing options...
yammerhammer98 Posted January 12, 2006 Report Share Posted January 12, 2006 409Banshee, How much is your time/physical effort/phychological well-being worth? A few months ago I picked up a stock swingarm with very good bearings on FleaBay for $50, including shipping. You might be better off tossing it. Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 12, 2006 Report Share Posted January 12, 2006 I have a stock swing arm lying around, needs new bearings, you pay the shipping you can have it, hows that sound?? Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted January 12, 2006 Report Share Posted January 12, 2006 been threw this exact same senario with my buddys shee get out the sawsall and cut either side, all parts are avail from Yamaha Quote Link to comment Share on other sites More sharing options...
409Banshee Posted January 12, 2006 Author Report Share Posted January 12, 2006 409Banshee, How much is your time/physical effort/phychological well-being worth? A few months ago I picked up a stock swingarm with very good bearings on FleaBay for $50, including shipping. You might be better off tossing it. 458608[/snapback] Ain't worth too much now anymore. I've beaten on this thing so bad that I have dented the frame in a few spots. I thought about getting a new or used swinger, but at this point, it's gonna be worth it. Quote Link to comment Share on other sites More sharing options...
409Banshee Posted January 12, 2006 Author Report Share Posted January 12, 2006 I have a stock swing arm lying around, needs new bearings, you pay the shipping you can have it, hows that sound?? 458612[/snapback] PM sent! Quote Link to comment Share on other sites More sharing options...
409Banshee Posted January 12, 2006 Author Report Share Posted January 12, 2006 Anyone got an idea on what carb size I may have? They are Mikuni. What do I measure to find out what I got? Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted January 12, 2006 Report Share Posted January 12, 2006 measure the bore size that goes into the intake boot, it is in mm's like my kehien pwks measure 39mm's on the intake boot side. are your carbs flat slides or round? meaning the slide that goes in the top of the carb will be round or flat, and some are d-shaped Quote Link to comment Share on other sites More sharing options...
fast87 Posted January 13, 2006 Report Share Posted January 13, 2006 before you cut it out, i spent almost a week pounding on my bolt and it didn't budge, same exact problem u have...i ended up starting with a smallish drill bit and working up to the 5/8" size bit on each side(do 1 side more than the other so u can hold the nut or bolt head to keep the bolt from spinning with the drill bit)..just drill away with a strong corded drill and you'll get it...took a good 2-3 hours of drilling/sharpening but it's worth it..unless your swinger is junk anyways, good luck man i've been there and done that ~Mark~ Quote Link to comment Share on other sites More sharing options...
GYTWYPT Posted January 13, 2006 Report Share Posted January 13, 2006 WOW Some one needs a HYD press. Quote Link to comment Share on other sites More sharing options...
