what size swinger with 10mill cub
reded..
is your bike hard to ride in the sand with that 6 over..also what size paddles you are you running
may have to go with 8..I want to be able to let her ripppp
458184[/snapback]
last i knew he was runnin 21x12x8 (i think) 10 paddles.. i think i also remember him packin the front end quite a bit.. i dont think a +8 with 10 paddles with your 10mm is gonna cut it.
my 4mm cub with those same tires, the 10 paddles, wanted to bring the front end up pretty easily. i have a +4 on mine. i would say that +8 would be the very shortest you could go and still be able to launch it, but im thinkin +10 sounds better..
I'm running +8 with 14/45 gearing, 22 inch 10 paddle ultralights with my 4mm cub and I have trouble keeping the front end down when I launch. Good luck going any shorter than that with the 10mm. You can get away with shorter for general duning but dont expect to win any races trying to keep that front end down coming out of the hole...
Just my 2 cents. :cheers:
