no fear zac Posted January 11, 2006 Report Share Posted January 11, 2006 Has any body tried running nitro methane in there mod. motor? If so what % did you use? Jetting(35mm)? Thanks Zac Quote Link to comment Share on other sites More sharing options...
enFORCER Posted January 12, 2006 Report Share Posted January 12, 2006 Well nitromethane will turn a good motor to junk real fast!!!! But if you are going to try it, start with about 7% and go up 5 sizes on your jets. I am asumming you are running alcohol, because nitromethane does not mix with gas. There for you will most likely be drilling your jets out.If your not running a fuel pump, then you will need to get one. Hope you don't have a nice set of chrome pipe's. Because nitro burns so slow that it will blue your pipe's the first time you start it up. Unless you have money to waste, then I would stay away from it.... Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted January 12, 2006 Report Share Posted January 12, 2006 You can use the Klotz nitro additive. It's actually nitro-propane, so it mixes with gas or alky. Quote Link to comment Share on other sites More sharing options...
snowprophet1 Posted January 13, 2006 Report Share Posted January 13, 2006 I played w/alky, but I've heard the same thing that enFORCER just said. Expect a lot of bad things to happen. The klotz nitro additive smells nice, but doesn't pack much punch. Klotz makes cozox which, if you mix the 1 gallon of cozox (sounded out as ko-zok) w/4 gallons of premium or race gas, you will have 5 gallons of oxogenated fuel which DOES make more hp (jet up a little for it). Ultra 94 by VP racing fuels is oxygenated also. I know those will give more HP, and I know alky will give more HP, but I can't say how much of a difference there is. Alky probably has more potential because of all it's cooling, etc. The real Nitro is wicked and makes the power, but at a price while learning. Quote Link to comment Share on other sites More sharing options...
