Shee will not rpm!
I unhooked my tors and still the same thing. It will rpm in neutral but as soon as i put it in gear it has no balls. I replaced the reeds checked the carbs evrything i could think of and nothing. It has a 2 into 1 motofast pipe on it now but i have a set of fmfs to go on it. you think that may be the problem?
Check the exhaust coming out of both pipes. Are they equal pressure?
Probably not. Try switch spark plug wires and see if its still not firing on the same side. If the problem moved to the other side its electrical. If it didn't, then its:
Carbs out of sync
low compression
bad reeds
airleak
plugged jets
case leak
different jet sizes in each carb
old spark plugs
Think that's all of em...
I had the same thing with mine, after a few hours in the shop I was told that
it was something in the wiring harness or the stator.Has your wirring been hacked? The rigth side never warmed up and thru mass fuel out on my bike. Make sure your slides are in correctly because there is a cut out in them that is directional.
I was also told to check the trans fluid for discoloration from a case leak.
Have you checked compression?
