Slammin Full Bore Posted January 6, 2006 Report Share Posted January 6, 2006 i just put a set of fattys and turbinecores on my 05 banshee, i also put in a K&N. I was told by a couple friends with the same set up to put in the 280 mains. I did that. Everyone told me i would need to mess with the airscrew, because they all said my bike wouldnt start. Well it started right up and idles fine, i rode it up and down the street and it seemed ok. Do i desperately need to fiddle with the airscrew. Or can it wait till after i go riding tomorrow. I just dont want to lose alot of performance because of it. Thanks guys. Quote Link to comment Share on other sites More sharing options...
ellison445 Posted January 6, 2006 Report Share Posted January 6, 2006 I would check those plugs before ridding it hard Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted January 6, 2006 Report Share Posted January 6, 2006 the air screws should be about 2 1/2 turns out but if it isnt broke dont fix it... Quote Link to comment Share on other sites More sharing options...
jlh Posted January 6, 2006 Report Share Posted January 6, 2006 i just put a set of fattys and turbinecores on my 05 banshee, i also put in a K&N. I was told by a couple friends with the same set up to put in the 280 mains. I did that. Everyone told me i would need to mess with the airscrew, because they all said my bike wouldnt start. Well it started right up and idles fine, i rode it up and down the street and it seemed ok. Do i desperately need to fiddle with the airscrew. Or can it wait till after i go riding tomorrow. I just dont want to lose alot of performance because of it. Thanks guys. 455932[/snapback] Turn both air screw out 2 full turns and you should be ok I have close to the same set up you have and mine are 2 turns out for sea level rideing and it runs fine. What size are your pilots I have 280 main and 22.5 pilots. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted January 7, 2006 Report Share Posted January 7, 2006 Depends on what your shee likes and how cold it is outside...I always find the fmf shees to like the .5 turn out around here, but when I went to Glamis I jetted a shee that liked to be 2.5 turns out, so just try fiddling w/ it. It'll affect your throttle response. Best way to do it , is to get it warmed up, put it in neutral, whack the throttle real quick to see how fast it response, adjust the air screw, repeat process. Quote Link to comment Share on other sites More sharing options...
