Ford F-350/ Gmc 2500 wheel fitment
pimp559
I believe they will fit, bolt pattern should be the same. sometimes you run into a problem with actual axle being to big to fit through center of wheel....ie.
all the big three use the same differentials made by AAM (American axle Manufactuerers) all the internal components are interchangeable, what won't be is if you are taking a wheel from a 9 1/2" eight lug and go to 10 1/2 or 11 1/2
because of axle size but since you are going from a 1 ton to a 3/4 ton, I am guessing to a smaller rear end, still eight lug, it should fit. bottom line give it a try.
ford and dodge are interchangeable, not chevy
453996[/snapback]
not true, I putt a set of 99 dodge wheels on my grandpas 72 gmc and they bolted right on. the chevy wheels will not fit a dodge because the hole in the center of the wheel is smaller. 98 and newer superduty wheel will not fit dodge or chevy because they use a metric bolt pattern.
ford 170mm / 25.4 =6.69 inchs
chevy and dodge =6.5 inchs
