Help wont start!
KJO89
:angry: My freind was riding my banshee and it stalled. So we started it back up and it stalled when it started to accelerate. Then it wouldnt start. We let it sit for a few mintues and it started and did the same. Now it wont start at all. Anyone know what this is? Help please!
Maybe when you stalled it those 3 times you fouled the plugs...check them and wipe them dry to make sure they arnt all wet, or else they wont spark, or just put new ones in, and let us know if that helped at all
Edited by Dinner
i changed the plugs so thats not the problem, and i just unplugged the tors and still no change. :shrugani: when i kick it over the lights dont light up or anything either.
Edited by KJO89
need a little more info here. was it running fine before it stalled out? almost sounds like you just need a good carb cleaning, or maybe air filter? if the plugs are new, make sure your getting spark to eliminate electrical issues before tearing into every electrical component. start with the simple things first. getting spark, getting fuel, carbs/filter clean, crossover tube in place, choke functioning properly, fouling plugs, bad reeds, loose/dirty connections etc. then if it still won't fire up, look a little deeper. B)
What is the compression . Maybe he siezed it up ! :(
  • 2 weeks later...
ok if it still doesnt work check the resistance on your ignition coil. mine did that and my ignition coil was shot. The resistance should be between 1000-4000 ohms. if that is right see if there is a short between a black wire in the harness and orange one. If there is then your bike will not start until you repair that. the ignition coil would be where i would start.
