Axion Posted December 25, 2005 Report Share Posted December 25, 2005 im looking at buying shocks from banshee's around my area i have a 4 inch extended swing arms but it has been moded so that stock shocks fit what other year's of banshee rear shock's will fit? i have been told any and i have been told some may have to be altered Quote Link to comment Share on other sites More sharing options...
Hilarious Posted December 27, 2005 Report Share Posted December 27, 2005 I think just about any year from 91 to current would fit. I would think you would be better off going with some aftermarket shocks that are set up for the wider a-arms. You would most likely bottom out with the stockers from the extra leverage from the wider a-arms. Quote Link to comment Share on other sites More sharing options...
Quadracer18 Posted December 29, 2005 Report Share Posted December 29, 2005 I think just about any year from 91 to current would fit. I would think you would be better off going with some aftermarket shocks that are set up for the wider a-arms. You would most likely bottom out with the stockers from the extra leverage from the wider a-arms. Word. Quote Link to comment Share on other sites More sharing options...
sheenut05mx Posted January 19, 2006 Report Share Posted January 19, 2006 you'll want to revalve the rear shock if using the stock one with the exteded swing arm. GOLD VALVE makes a good valving kit for many applications.(dunes, MX, ect.) For way cheaper than buying a new aftermarket one. ALL the shocks are the same but Iam pretty sure that there was valving changes made over the years. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted January 19, 2006 Report Share Posted January 19, 2006 All years are the same. Colors change and that's it. An older shock may be more likely worn out than a newer one though. I'd revalve for a plus 4 if it was me. Quote Link to comment Share on other sites More sharing options...
sanddragon2004 Posted January 20, 2006 Report Share Posted January 20, 2006 usutally with a plus 4 You can just change the spring, and you will be ok. an eibach spring is what i would use. Quote Link to comment Share on other sites More sharing options...
Shane Posted January 23, 2006 Report Share Posted January 23, 2006 you'll want to revalve the rear shock if using the stock one with the exteded swing arm. GOLD VALVE makes a good valving kit for many applications.(dunes, MX, ect.) For way cheaper than buying a new aftermarket one. ALL the shocks are the same but Iam pretty sure that there was valving changes made over the years. 461821[/snapback] The gold valve is an excellant option. The problem is the stock banshee shock is engineered so that is cannot(isn't supposed to be) rebuild. If you don't know what your doing you can get hurt or ruin the shock itself. We can help you just give us a call. There is never a charge for advice. Shane 219.313.1424 Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted January 24, 2006 Report Share Posted January 24, 2006 The gold valve is an excellant option. The problem is the stock banshee shock is engineered so that is cannot(isn't supposed to be) rebuild. If you don't know what your doing you can get hurt or ruin the shock itself. We can help you just give us a call. There is never a charge for advice. Shane 219.313.1424 463498[/snapback] alright Shane where do you live in Indiana Quote Link to comment Share on other sites More sharing options...
