Guess my HP
Wallrat
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Good guess on your HP, you get the fork. lol
Get a clutch in there and shee should pick up some hp to the ground. I really thought with a 4mm dune port and single carb the torque would of been higher though. We dynoed a customers play/dune port 350cc on gas at 40 trq and 70 hp ! He did have dual carbs though and they do help some.
Oh and I didn't have a sniffer on this dyno so no fuel/air graph.
451699[/snapback]
how did you know the jetting was somewhat right with no sniffer???
thought wicked atv had a nice dyno facility???
451752[/snapback]
How do you know your jetting's right without using a sniffer? Same way, we just jetted it on the dyno instead of at the dunes/trail.
that makes no sence.  did they get a computer read out of what the air fuel ratio was.  the reason im asking is how or why you picked that setting of your needles and pilots, mains.
451883[/snapback]
im guessin he just adjusted until he made the most power and where the curve looked best??...the sniffers are nice tho..get your jetting spot on and then when u get out and run outside might have to do just a little fine tuning..
I always jetted to my plugs and when I went to the dyno, my jetting was spot on w/ the most hp..I tried richer and leaner and lost hp...although that was w/ 93 octane. Plugs look totally different w/ 114 octane. Either way, exhaust pipes are designed for max hp at 1200 degrees..if your too lean, then you'll be hitting temps a lot higher and the hp will suffer as your coming off the tuning of the pipe.
  • 2 weeks later...
Ah man I haven't even thought about it in a long ass time. I briefly tried scanning the graph but wasn't having any luck. Didn't feel like dicking with it so I just quit. I'm thinking about taking her back in and just doing a few runs now that I've got the new clutch. But at the same time, it feels fast under my ass so do I really need a number to verify that?
