shee13 Posted December 20, 2005 Report Share Posted December 20, 2005 my bike is a 1998 banshee mods include.... had a light bore to clean it up a while back but has low hours,pro flow filter,modded airlid,cool head,procircuit pipes,14 tooth front sprocket,stock reeds,looking to add some stuff the bike runs great but time for alittle more.i would like to keep running 93 octane any ideas of stuff i can do to make her alittle quicker,thanks guys Quote Link to comment Share on other sites More sharing options...
odaen Posted December 20, 2005 Report Share Posted December 20, 2005 get an adjustable timing plate. after that, might wanna think about getting your cylinders ported. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted December 20, 2005 Report Share Posted December 20, 2005 V-Force reeds and cages, either 2's or 3's. Quote Link to comment Share on other sites More sharing options...
shee13 Posted December 20, 2005 Author Report Share Posted December 20, 2005 what exactly does the timing plate do for ya,i figure it probably advances the timing?hard to install? Quote Link to comment Share on other sites More sharing options...
Banshee17Racing Posted December 20, 2005 Report Share Posted December 20, 2005 Yea, it advances the tiiming. Most people advance their timing +4 degrees. Get a port, V-force reeds, timing plate, and lighten your flywheel. The last three aren't going to make a huge difference. The port is pretty much your next option for more power. EDIT: The timing plates are really easy to install. They're located behind your flywheel under the stator cover. You'll need to get a flywheel puller to remove the flywheel, and while its off you might as well get it lightened. You just unbolt the stock timing plate and bolt on the advanced timing plate. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted December 20, 2005 Report Share Posted December 20, 2005 You'll also need an impact, a clutch holding tool, or make yourself something to hold the flywheel in order to get the nut off/on. Quote Link to comment Share on other sites More sharing options...
shee13 Posted December 20, 2005 Author Report Share Posted December 20, 2005 thanks for the info guys,does anyone no who does good porting in the newjersey,pennsylvania area? Quote Link to comment Share on other sites More sharing options...
shee13 Posted December 20, 2005 Author Report Share Posted December 20, 2005 any particular pipes gunna wake it up any? Quote Link to comment Share on other sites More sharing options...
iceman Posted December 20, 2005 Report Share Posted December 20, 2005 i learned you dont actually need a new timing plate. oval out the holes on your stock one with a dremel to accept +4 degrees. Quote Link to comment Share on other sites More sharing options...
Banshee17Racing Posted December 20, 2005 Report Share Posted December 20, 2005 i learned you dont actually need a new timing plate. oval out the holes on your stock one with a dremel to accept +4 degrees. 450203[/snapback] You could do that, but how are you gonna know where +4 degrees is at? I just think the $35 is worth it because it's adjustable. You can set it to whatever you want. Quote Link to comment Share on other sites More sharing options...
mouse Posted December 29, 2005 Report Share Posted December 29, 2005 You could do that, but how are you gonna know where +4 degrees is at? I just think the $35 is worth it because it's adjustable. You can set it to whatever you want. 450232[/snapback] look into a powernow valve there pretty cool better throttle responce real easy to install Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted December 29, 2005 Report Share Posted December 29, 2005 The timing plate, and V-Forces make a pretty decent difference in my opinion. Nothing is going to give you the initial bang for the buck that pipes will over stock. Porting is about the closest, and could be comparable HP per $$. I'm with Banshee17, the $35 timing plate from RS is well worth the peace of mind. Also, you can get a tool, I believe mine is from Pro Motion, that is a combination flywheel holder, and clutch holder. It looks alot like a set of vice grips, and works great! Quote Link to comment Share on other sites More sharing options...
