Bashee Firing Only On One Side PLEASE HELP!
Infamous039
I have a 94 Banshee with, FMF Pipes and Silencers, 12/41 gearing, Uni Airfliter with open box, TORS removed, jetted professionally. My bike starts and both of my pipes release smoke and is firing properyl. After letting run to warm up one cylinder seems that it is losing spark somewhere b/c only a little bit of exhaust is coming out but the other side is firing perfectly. I took my plugs out and the were a chocolate brown color but one side was a little wet on the plug, so I put new ones in and the problem was still there. What can I do to fix this and What is the problem with it?????????? It is causing the bike to run very poorly and bogg out?????????????
Edited by Infamous039
Sounds like one side is rich. Probably have a stuck float but could also be different size jets (professionally jetted doesn't always mean you get a rocket scientist). It could even be that your carbs are out of sync. Worst case would be that you have an airleak and the guy jetted it to make up for that one side being extra lean. I'd spray some carb cleaner all around the boots and reads, then I'd pull apart your carbs and clean em and check the jets. Then put em back on and sync em up. See if that helps. Also make sure your choke tube is still on, I believe that could cause problems as well.
