shee4202 Posted December 17, 2005 Report Posted December 17, 2005 I'm thinking of going with an aftermarket cylinder with powervalves, but i'm not sure which one to go with. I talked with trinity and they said that the 421 kit will push out 115hp on race fuel and you have to use race fuel. Thats with a 4mm crank. I dont really know any thing about the t-rex kit except they use cylinder sleeves. Does anybody have either of these kits and if so how is it. what is a better kit to buy Quote
reded Posted December 17, 2005 Report Posted December 17, 2005 You may wanna talk to someone other than Trinity. I've personally never heard of anyone getting 115 hp out of a 4mil motor on gas. I think they may be juicing the numbers a little bit. Personally, I would go with the Cheetah cyls due to the fact that they are newer technology and its easier to get big power out of them than the T-Rex. They will both run awesome in the hands of the right builder but the T-Rex will require more work. Go do some research over at Planet Sand, theres more information over there on builders and engine setups than you can shake a stick at. Quote
locogato11283 Posted December 17, 2005 Report Posted December 17, 2005 go with cheetahs..here are some places you might wanna talk to.. fast racing a&s packard nate mccoy ssr redline there are others..go to planetsand business directory if u want numbers and stuff.. Quote
Malott 1 Posted December 17, 2005 Report Posted December 17, 2005 There is alot of builders that do a hell of a job on the cheetah like loco listed. If you want information on the T-REX you should call K&T. Quote
Too Many Toys Posted January 6, 2006 Report Posted January 6, 2006 115 hp out of a 4mm cub sounds pretty high. The T-rexx is a great cylinder. They just haven't been promoted as much as the cub, Calvin does a great job advertising to builders. I don't think the 4mm cub has powervalves though, or any of the cubs for that matter. Call Kim at K&T if you want a T-Rexx. www.ktperformance.com He is building me a 10mm right now and has been awesome to work with. Quote
rocketboy Posted January 7, 2006 Report Posted January 7, 2006 id get a cheetah ,the trex requires a ton of port work to extract the power thats equal to the cheetah engines with just a clean up port . might as well have a badass motor right fro m the start especially when the cost of these is so high . Quote
